Question about Gaggia Titanium Espresso Machine
Cant ventilate It says to ventilate but it doesnt work. I am using the plunger sent with the unit. Is there a trick?
  • mayo Feb 27, 2012
    So which tube and how do I unclog it?
Trying to wire a honeywell bath fan control to a panasonic FV-04VE1 ventilator fan cant figure it out. Fan control has two black wires and a ground and the fan has blue-yellow-and orange wires, what do i...
well, this is an interesting monster. It appears that the unit needs to have constant power and a control circuit. Here is the manual, wiring diagram is on page 8. So, you will need to feed power directly to the fixture, after this, you will need a minimum of 3 wires and a ground between the fan and switch location. Power goes down to the switch on the orange wire, When power is sent from the switch back up on the yellow wire, the unit is on, when this connection is open, the unit is in standby. When power is sent from the switch up the blue wire, the unit is in hi, when this connection is open, the unit is in low. I do not know about the switch you are trying to use, because you did not provide a model number. If I were wiring this unit, I'd use either two switches or a stacked switch.
Sep 17, 2011 | Broan-NuTone FAN CONTROL SWITCH
I forgot my password but i reset it from facbook and facbook sent https://m.facebook.com/reset.php but I cant use this adres please help me thank you
the reset password link should be longer than that. If the click doesnt work or it doesnt get you anywhere you may need to disable your internet security software because it may be blocking the redirect. If this doesnt work contact Customer Support at Facebook and explain what happened. Do this quickly.
Jan 11, 2011 | Facebook Social Network
The on button is glowing red?
You, sir, would have what is called the red ring of death, it is caused when the xbox is left in a low ventilated area and the cheap solder that microsoft used on the gpu melts together creating a short. If it is still under warranty it can be sent in for repair, but if not then you are S.O.L., unless that is you know someone who will void warranties and use the heat gun trick.
Oct 22, 2010 | Microsoft Xbox 360 Console
Doesnt turn on
unit must be fully assembled, then add fruit and press down with plunger
Jul 17, 2010 | Jack Lalanne Power Juicer 250 Watts
How do you remove the rear spark plug on the drivers side of a 2000 ford f-150? 4.6 liter v-8, I just cant seem to get it with a socket, it is real tight. Is there some trick or special tool to use? Chad...
There is no special trick, use the smallest socket handle there is, you may have to remove the wire from the rail, based on the photo you sent me, it is the same and the previous email I sent should help. Good luck.
Sep 15, 2009 | 2000 Ford F150 Flareside SuperCab
Mikuni BST33 choke plunger ceased
Soak it in WD 40. If possible make a pool of the WD40 and let it soak for 24 hours. Gently try and move it but you have to be patient dont force it early if it is really siezed. You could apply some gentle heat with a hot air gun but if the carbi is still assembled remember you have plastic parts inside, no more than 70 degrees C. If this fails take the unit apart and you may be able to apply some pressure from the underside or use compressed air but be carefull it doesnt shoot out and become lost forever.
Sep 06, 2009 | 2000 BMW F 650 Strada
I cant see anything on the tv and i have 'the ring of fire' HELP!
your 360 is suffering from the "red Ring of Death", and will need to be sent away for repair or replaced outright.
Jun 12, 2009 | Microsoft Xbox 360 Console
Message sending failed
Reason of this Problem:
Actually it happens due to mem full in Sent Items with Pending Status.
Solution:
Just delete one message from Sent Items.
Better if you delete all messages from your Sent Items, as you will face again this problem if again Sent Items fulls with messages having status Pending.
Regards,
Shakir Idrees
Mar 23, 2008 | Nokia 1112 Cellular Phone
I cant send an recieve message..
heres a handy trick i use all the time for that go to nokiausa.com and download settings for the nokia 1030 to your phone that model has all the settings for usa i use this for all models of phones to trouble shoot messaging problems remember after you download remove battery and sim for a min then replace and try sending a message if doesnt work contact servics provider and make sure provisioned in billing system
Feb 14, 2008 | Cell Phones
Malfunction 8
Short answer: You need to lubricate the plunger mechanisms in the brew unit.
Long answer: There are two rubber o-rings - one in the base of the brew unit and on the plunger that descends into this to form a seal. There are great instructions on how to take apart, clean and lubricate the brew unit here:
http://www.buessert.de/Technik/Jura-IMPRESSA-S95/Cleaning.htm
...but they are not for the faint hearted.
There is also a cheats way too which I use.
First, get some SILICONE lubricant. It needs to be Silicone. You can get it from ACE for $3.
Remove the door / funnel mechanism from the powder inlet - it just lifts out.
Usign a flashlight, take a look inside where the coffee grind goes. You will see a cylinder with a plunger mechanism at the bottom. You need to lubricate the ring on the bottom plunger and the tope one (which you cant see this way).
Use the flashlight and a knitting needle and place some silicone at the base of the plunger - you will see what I mean when you look inside with the flashlight. Also put some around the top lip of the cylinder (for the upper plunger). It is sticky and messy.
Press the "rinse" button.
You can do this a few times. The silicone will not affect the taste of your coffee. I tend to put a liberal amount in and then wipe off the excess with a kitchen towel on the end of the knitting needle.
This is fiddly, but it works. I do this in between complete disassembly, which I do about once per year using the above instructions. If you need to replace the o-rings, you should be able to find suitable replacements at a local hardware store but this is a trial-and-error process, I'm afraid. I have never ordered the ones linked to on that page.
Hope this helps.
Now, if only I could work out how to fix the leak from the rear....
Rgds, John
Jan 12, 2008 | Jura Capresso Impressa S90 Espresso...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
19 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
