Question about Acer Aspire m5640 PC Desktop
I have initialized M5640by the advice I got from ACE technicia, but it still freeze
I am still having the freeze problem after I initialized it. I cannot turned off the computer when it is freezed, and the only solution to turn off the computer is take the plug out. I received Notice of Class Action from Ace. I donot know which settlement I
  • Hiromi Nagao Feb 26, 2012
    I turned my computer up. Acer Screen with Del: Enter setup, F12: Boot Menu. I chose Del: option, and hold the key for a while, but nothing happened. Freezed again. Plug off and turned up again. The Acer Screen disappeared within a minute, and showed Window Error Recovery screen-set repair, and then Startup Repair. Diagnoses and Repair Details said, System Disk=/Device/Harddisk0, Window Directory=C:/Windows, AutoChk Run=0, Number of root causes=1
    I went to internet checking my mail. It freezed again.
  • Acer Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or you might go for factory defaults
Restart your computer now as soon as you hit the power button keep on holding Alt key & keep on tapping F10 key Alt+F10 it will open the recovery console select full factory restore and follow on screen instruction
(Note:this will erase all datas on the computer)
hope this helps you
Posted on Feb 25, 2012
  • Brian Sullivan
    Brian Sullivan Feb 26, 2012
    Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
    the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
    even something as small as a faulty electrical extension or fan lead can cause you problems
    computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
    motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
    check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
    also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
    check you CPU make sure its securely seated and has thermal grease might be getting to hot
    another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
I have a Galaxy Ace which I loved until recently. Its started freezing up alot. This morning my alarm didn't go off at 5 because the time on the phone said 2:27. I depend on this phone for my job!
If your Galaxy Ace suffers from this problem do not bother change the firmware, or try setting the WiFi Sleep to "Never" or trying any fix. The problem affects a small number of Samsung Galaxy Ace handsets, and if you have this problem your phone is defective. Have it replaced
Feb 09, 2017 | Galaxy Cell Phones
How do I sign in to on line banking
Go to your banks web sits click on their bank instructions for setting up a on line account, if you already have one, you will need to type in your user name and password. If you still can't get logged on, call your band for advice. Have account info ready.
Feb 03, 2015 | Ace Hardware Ace Home and Garden Sprayer
Samsung ace screen not responding to touch
Backup everything and reset the phone.
Jan 06, 2014 | Android Galaxy Ace
Owners manual
sorry i dont have any owners manuals to send you ask an other technicia perhaps they will be able to help.
Jan 01, 2012 | KitchenAid Refrigerators
Ineedpartsforpowerglidetrimmer
I have run into the same problem. I lost the spring for the line feed. I contacted customer service listed on the manual. (What a joke!) After two weeks waitThey are only an importer of the Power Glide brand line and have NO PARTS other than replacement spools. I have now contacted Ace Hardware customer service and Jeannie there advised that this unit is discontinued by both Ace and the manufacturer.
My advice: DO NOT BUY ANYTHING WITH THE POWER GLIDE BRAND. THEY CAOULD NOT CARE LESS ABOUT CUSTOMERS.
Aug 19, 2010 | Ace Hardware Power Glide Cordless String...
Require assembly schematic for shimano dura ace shifter . left shifter lever failed, will not activate the front derailler, disassembled, found nothing broken, require advice regarding proper reassembly...
log onto Shimano.com, it is probably the limit screws (the two screws that limit travel) or you have a faulty ratchet in the lever, try the shimano website anyway they have great tutorial and manual support
Nov 14, 2009 | Shimano Dura Ace Front Derailleur Fd 7800
I have a 52
The decoder in this set is showing signs of malfunction around $150 for the part.. I would have it replaced before more goes as time passes if its under warranty specially take it in before other things fail is my best advice for you if you know how to replace the decoder please visit www.partstore.com to purchase your part, Thanks for using fixya.com please leave positve ratings and feedback for your totally free answer today!
Nov 10, 2009 | Samsung 52 in. Flat-Panel LCD HDTV
I have an hp 2710p and I have purchased 2 batteries but the batteries will not take a charge
its mean your computer has a fault, consult a qualified technicia/authorized service center for assistance.
Nov 27, 2008 | HP Computers & Internet
Freezes at system initializing screen
Please go to my blog to fix your problem. http://terminaltech.blogspot.com/2007/04/iriver-h10-freezing-at-initializing.html
Mar 14, 2007 | iRiver H10 MP3 Player
Acer Aspire m5640  PC Desktop Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
