Question about Sharp Viewcam VL-Z3U Mini DV Digital Camcorder
Sharp VL-Z3U E007, dew problem, mini dvc problem
Initially, E007 error. Authorized Sharp repair shop said was d/t dew error, that Sharp was honoring the problem as was inherent to this unit. Have sent back three times--capstan motor replaced twice. ?? Same E007 error. Now will not even accept TDK tapes. Sharp tells me dew error has nothing to do with E007 error, no longer authorizing repair. As repair shop has been securing authorization, I've no idea what problems have been related. However, the problems have been consistently the same from the outset. Sharp doesn't make the tapes, they tell me--say no longer make this camcorder. They blame the tapes I'm using. Cannot record nor play the 50-75 tapes I have. I don't reuse tapes. Would like to be able to download to my comuter. Sharp personnel indicated couldn't be done. Radio Shack said could, purchased firewire cable, can't get to download. Help! Purchased camera in 2004, problems began within the first year, but presumed warranty repairs would remedy. Boy, was I wrong.
3 Suggested Answers
SOURCE: E007 and DEW indicator
Few restarts fixed this for me but I know this is going to come back again soon.
Posted on Jun 24, 2007
  • 298 Answers
SOURCE: Help!! Can not connect my Sharp ViewCam Z VL-Z3U Through FireWire
Try searching these posts to see if they will help your problem. Seems this is common. See the link below.
http://www.fixya.com/tags/VL_Z3U
Posted on Mar 26, 2008
erleichda1
  • 7 Answers
You've probably fixed this by now, but since nothing is posted:
I have an older Sharp digital camcorder, one of the first. It's the VL-NZ100 and Sharp does not support transferring the video to a PC with this camcorder because they did not include the cable to do it. That said, I WAS told by Sharp that I could figure it out myself if I got a fireware (IEEE) cable.
I got a very inexpensive IEEE-1394 firewire cable, set my camcorder to Tape/VCR, connected the cable to my PC and my camcorder, and Windows Vista recognized it. It asked if I wanted to transfer the video and it just walked me through the whole thing! This is built in to Vista, so if you have the operating system, you are set.
If you don't, I don't know if you can download Windows Photo Gallery from Microsoft. I know that you can download Windows Live Photo Gallery but I don't know if that has the same functionality. You didn't mention what operating system you have.
And FYI, I didn't need drivers.
Posted on Jun 11, 2009
I have a sharp vl-z300 camcorder which is displaying an e007 error can you help
The 007 error is associated with dew sense and is a fairly routine repair.
PC board traces open at System Control IC, and will need to be hard-wired. I would suspect that any reputable electronics service facility should be able to perform this repair.
To find a Sharp authorized center in your area, contact Sharp support at sharpusa.com/CustomerSupport.
Hope this helps (remember to rate this free answer and leave a testimonial).
Sep 27, 2011 | Sharp VL-Z300U Mini DV Digital Camcorder
I have a sharp vl z300 displaying an E007 FAULT .CAN YOU HELP WITH WHAT IT IS AND IS IT WORTH FIXING
My cam say in the display dew and shut off
It sounds like you have moisture in the camera. Place it in a warm dry place for about 24 hours. Also make sure you take the battery out of the camera too.
Regards.
Apr 12, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
Bypassing of DEW sensor
there is no way to bypass it, but simple modification is available to correct this problem. contact any sharp authorized repair center.
Sep 13, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
What doe DEW mean? The "DEW" sign keeps coming on and then shutting off..
DEW sign indicates high humidity level inside the camcorder. What you experiencing has nothing to do with humidity, It is a faulty connector on a junction board. Sharp has fix for it.
Jul 12, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
Sharp viewcam
my sharp viewcam model no VL-E650U CAN NOT PLAYBACK IN COLOUR AND SOUND
Apr 18, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
Sharp Viewcam z
either it has moisture in it (let it dry), or the dew sensor is bad and needs to be replaced.
Nov 29, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Dew indicator
look inside the camera to the front.wou will see 2 solder bloba,run a line of solder between them to by pass the dew,it works
Nov 04, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Dew liht comes on and camcorder shuts off
I had the same problem with a VL-Z3U, there was no home fix, the dew sensor needed replacing costing $130 CAD
Jun 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Mar 30, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-Z3U Mini DV Digital Camcorder Logo
446 people viewed this question
Top Sharp Video Cameras Experts
noel
noel
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
