Question about Dryers
Hotpoint TL22 tumble dryer has no heat, would it be the stat or heater?
Tumble dryer works, but has no heat, would it be a stat. or heater at fault?
SOURCE: hotpoint aquarius tumble dryer not
check the drum ,if its a going aniclock wise and not changing ,
Posted on Mar 27, 2009
  • 1525 Answers
SOURCE: Hotpoint CTD40P tumble dryer only runs cold.
hello check the heat sensors first good luck
shaun
Posted on Aug 04, 2009
apart4u
  • 213 Answers
SOURCE: hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Posted on Jan 08, 2010
Testimonial: "yes this problem was the thermostats now fixed thank you"
barkencoa
  • 3463 Answers
SOURCE: can't work out how to fit new belt to my tumble
You need to remove the rear panel the top console panel,,and then remove the whole cabinet to gain access to the drum and belt.
Then you need to release the front panel at the top to enable you to fit the belt.
Hope this helps.
Posted on Jan 19, 2010
heatman101
  • 43501 Answers
SOURCE: Tumble dryer (Hotpoint TDC62p) No Heat
Here is a tip that explains the troubleshooting2_bing.gif for electric dryers
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Mar 26, 2010
How do I change the thermostat on an Indesit IDC85
heater units have 2 or 3 starts ,check they work ..on some hotpoint dryers there is a stat on the front top right just under the timer as wire burns out then no heat ..WARNING TAKE OUT THE PLUG
Sep 16, 2015 | Indesit IDC85S Silver Electric Dryer 8kg,...
Tip
Common faults on a hotpoint tdc32
Common faults -
1 The heating elements can fail(meaning open circuit)
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuitboards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also bethe fault.
For Free Video help on yourHotpoint TDC32 Tumble Dryer USE THIS LINK
on Jan 17, 2010 | Hotpoint TDC32 Electric Dryer
Can't work out how to fit new belt to my tumble dryer it's a hotpoint aqurius dryer duluxe TL22.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Dryer elements are not heating up
this is the thermostats or the heater has blown. We have a full video library on appliance repair video’s
Common faults -
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
Dec 31, 2009 | Hotpoint Dryers
Hello I have a hotpoint tcp 1p tumble dryer
Common faults -
Dec 20, 2009 | Hotpoint Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius tdc32s not heating up
Common faults -
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Sep 03, 2009 | Hotpoint TDC32 Electric Dryer
I don't have any heat from my hotpoint aquarius ctd40G Tumble Dryer. I have cleared all the fluff from the condenser unit and unplugged the mains and tryed it all again but we still do not have any heat...
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Runs Cold no heat ? Tumble Dryer
Common faults -
Free tumbledryer repair videos
Jun 06, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Dryers Logo
52 people viewed this question
Top Dryers Experts
