Question about Black & Decker & Leaf Hog Blower / Vacuum
How to change fan blade BV1000
How do i get the fan blade out for a new one?
    New Friend:
Hi Geno,
I have the same problem. Reading previous answers it seems we need to remove the sparkplug, insert a bit of rope gently in to block the motor and once blocked the nut on the fan/impeller can be undone.
I'm going to give this a try on mine. Recommend we both proceed with caution, mate!
Posted on May 20, 2013
  • alex macphee Apr 15, 2014
    Must admit I'd forgotten about this. In the meantime I did use the rope trick and it did work :-)
I have a broken ceiling fan blade arm for Harbor Breeze Model #OM52-5B/Q1M (outdoor fan). Can I get a replacement arm or do I have to buy a whole new fan?
you will have to get 3 (4) blades as they have to be exactly the same
At this point I would advise a new fan because the settings of the blades have to be exact or it will wobble all over the place
to explain even with a new unit, the fan blades have to be measured from a fixed surface ( normally the ceiling
each tip of the blade has to be the same distance and the front and back of the blade measurements at the tip have to be the same on all blades
If you get it right the fan will spin without any movement
Mar 02, 2016 | Dryers
The fan is wobbeling
get a new blade perhaps
Mar 15, 2015 | Dryers
Hunter douglas ceiling fans
Call 1888-830-1326 with model # to order new blades.
Sep 20, 2013 | Dryers
Blade broke
Look up zorotools.com and they should have a fan blade you can use it is most anything you can think of so maybe you can find the fan blade you need. Hope this will help Norm.
Aug 06, 2012 | Windchaser 3-way Oscillating Fan
I have an Aloha Industries ceiling fan and one of the blades broke on it! How can I get just one blade?
Unfortunately you can't buy one blade. Blades are made in sets and have to be balanced within a few grams of each other. If you can find the supplier for this brand there is a small chance you may be able to buy a new set of blades but you will need to know the model as well. Blades aren't interchangeable between brands or models.
Most likely you will need to buy a whole new fan.
Jul 29, 2010 | Aloha Housewares (93645) Ceiling Fan
Fan vibrates real bad. Needs a new blade. 18 inch floor fan. Blade is weak and bends easily.
Stick a small weight to the end of one of the fan blades with some sellotape , run the fan , if the noise gets worse transfer the weight to another blade.
When the fan is running quietly go to the blade opposite to the one with the weight on and drill out a 10mm hole in the material.
Take the weight off and check for balance if it is still out drill another smaller hole in the blade till you get a balance
Drill the holes a the tip of the blade so that you get the best effect from the removal of material
This will save you buying a new blade
Oct 09, 2009 | Outdoor Concepts 18-Inch High Velocity...
Screws that hold the fan blade don't tighten up to the blades
replace your blades and washers and screws with a new ones.
Apr 07, 2009 | Hampton Bay 24002 Ceiling Fan
Broken mount attic exhaust fan
buy new blade or keep soaking shaft.collar with rust penetrant,
Jul 25, 2008 | Ventamatic Gable Mount Power Attic...
Removing ceiling fan blades
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Jun 13, 2008 | Angelo Brothers Westinghouse (r) Savona ES...
Need fan blade.
I tried every link and selection on the WeatherWorks website in an attempt to find product information, but that was a waste of time. It's the least-friendly and least-useable website I've ever seen. For a replacement fan blade try contacting this aftermarket parts supply company (below). They seem to have every type of fan-blade imaginable: Electric Trading Co. PO Box 692, New York, NY 10013 Tel: (212) 226-0575 | Fax: (212) 941-1796 http://www.blowerwheel.com/ sales@blowerwheel.com (Although, to be honest, I think it wound be cheaper to buy a whole new window fan...)
Jul 31, 2007 | WeatherWorks DB888 Floor / Box Fan
Black & Decker & Leaf Hog Blower / Vacuum  Logo
202 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
