Question about Ingersoll Air Tools & Compressors
Filter number for air/oil seperator XP825 year 1998
Look for filter number for the air/oil seperator as it is starting to pass oil on the out let tap
    Champion:
  • 205 Answers
Contact keltek the should be able to help
2300 E. Enterprise Parkway
Twinsburg, OH 44087 USA
(330) 425-3100 (330) 425-3550
Posted on Mar 08, 2012
What would cause compressor oil to migrate to dischage air.
If it is a screw compressor and by you saying you replaced the seperator i would say it it you need to check the scavange line. This is a pipe that goes to the bottom of the seperator filter and sucks any excess oil back into the bottom of the element (pump ) if this is blocked oil will pass down the line insted of going back into compressor. Check pipe on seperator and flex hose going from seperator vessel to bottom of element.
Jul 31, 2014 | OEM Air Compressor Genuine OEM Replacement...
My air compressor will crank and run for 7 to 10 minutes and then die just like you turn the key off.
well you didnt mention what year or model number you got but some of the better IR compressors have a fuel saver mode that if they don't sense any change in load for like 15 minutes they shut off could be what your seeing , or could also be a safety sensor on the seperator tank not seeing any pressure build up (bad or damaged sensor?)
Apr 15, 2014 | Ingersoll Rand Air Tools & Compressors
Petrol in my oil/ oil in the air filter.
You have a fuel tap problem and maybe a float vavle sticking in the carbs.oil in the air box is normal but if the is lots it due to the engine being overfilled with oil or in your case fuel
Oct 14, 2013 | 1998 Honda VTR 1000 F Firestorm
Oil leaking from back of air filter
Hi Robert, oil leaking from your air cleaner is caused by oil carryover from the engine. For what ever reason the breather system is not seperating enough oil mist and air from the piston downstroke. There are cheap and quick easy fixes and there are more exspensive ones. Start by trying the following:
1. Run your oil level half way between the add and full mark when hot.
2. Run oil breather lines from head into a TEE fitting below carb/induction module then a single line into a mini filter under frame.
3. Purchase Arlen Ness Super Sucker.
4. Replace umbrella valves and realign oil pump
5. Upgrade oil pump and cam plate
Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 19, 2012 | 2002 Harley Davidson FLHR - FLHRCI Road...
My Renault Clio 1.6 16v 2000 has started making a tapping noise from I think the top of the engine. Oil is topped up and no decrease in performance. Just tapping away! Any idea's and would it be an...
hi, just because you topped it up will oil it do'snt mean the oil good. the oil could be 4 years old and full of sludge the oil pipe filter filler can be partially blocked ( in the sump), the oil releif vale can stick open and pass oil back to the sump. the oil filter (changable external) can be partially block. to test oil is free to circulate START ENGINE TICKING OVER and TAKE THE OIL FILLER CAP OFF to see if oil comes out of the ROKER COVER. if not then the above applies
Sep 09, 2010 | 2000 Renault 181
Masport Lawnmower won't start
you likley will need a new air filter and a carb cleaning. when mowers are turned on their side. oil will seep past the piston and if your intake valve was open it can pass thru into the carb and also spoil your air filter. I am assumeing you have a paper air filter. start by taking off your air filter. then you should also pull the spark plug, place a rag covering the hole. then pull the cord a couple times. chances are that you will blow the oil out of the cylinder.
Mar 31, 2009 | Garden
Air Tools & Compressors Logo
90 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
