Question about Braun Activator 8595 Electric Shaver
8595 Pop-Up Trimmer Broken
My 8595 pop-up trimmer is broken, one of the thin plastic prongs on the side is broken and it disengages from the slide shaving mode controller. Can I buy the part and replace it myself or must it be serviced? I live in zip code 94588, where's the nearest repair outlet/shop if I need to take it in?
  • lance a Jan 15, 2009
    same problem with pop out trimmer on 8975 where can I get it repaired in zip code 10021. thanks, Lance
  • 10 Answers
Replacing the Braun 8000 Series Activator Motor Drive Unit. The Motor Drive Unit is a one piece unit containing the motor and shaver head. Cost $33.99 at http://shaveroutlet.com/.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Posted on Aug 27, 2009
Http://www.electricshaverstore.com/get_item_7030247_braun-housing-silver-activator-type-5643.htm
This is the best solution I've found. (Found it thanks to another forum). Its the whole casing which includes the trimmer. Frankly, I'm not going to argue with the price.
The shaver itself is easy to take apart. The part on the bottom (opposite from the shaver mechanism) pops off with just a slight bit of prying. Be careful not to break the pins though. Once you have that off, the narrow sides pop off pretty easily. Then you can remove the 4 screws opening up the interior.
Be careful at this point because there are a lot of parts that may fall out. (Perhaps take a picture as soon as you open it so you know where everything was when you opened it). At this point you can try your hand at fixing it (mine had 3 parts broken and loose inside), or you can simply switch it with the new casing (Which i'm going to do when I get it). Good Luck!
Posted on Mar 31, 2009
The trimmer assembly has come off completely, in one piece.
If the rest of the shaver works OK, then there may be a small detent on the slides that is broken; this could be on the trimmer grooves or in the mating grooves on the shaver body. In either case, you may need a new part.
If none are broken, then you may be able to press it back in the same way it came out; light pressure, but do not force. If unsuccessful, you may have to pry off the back to reinstall. A flat (not sharp) object inserted in the groove that runs around the body should pop it free; pry carefully as you work around the case. If unable, your options are to find a service shop or replace.
Apr 20, 2014 | Remington F5790
How to replace a drivers side window regulator & motor
Not as complicated as it sounds. First you have to remove inside door handle, usually a couple of hidden screws. Then, you need a thin trim removal tool or stiff putty knife to slip under the edges of the inside door panel. As you slide it around the perimeter, you should run into a number of pop fasteners. Just twist your knife and they should release. Unplug your control switch and remove plastic vapour barrier to access ports in the door frame. Assuming window does not operate, you may have to fiddle around a bit to disengage the motor/regulator ... There is always a way. Assembly is just the reverse.
Mar 01, 2014 | WLRA-43 Power Window Regulator for 2007...
Electric window motor doesn''t work needs replacement
Remove the visible bolt from the left side of the arm rest.
Remove the window switch/door lock/mirror controls by popping the entire panel out, may need to use a flathead screwdriver.
Slide panel off of door.
Pull vapor barrier loose on the bottom right side. This will expose a coiled spring and window motor. Tape the window in the up position using masking or packaging tape.
Mark a straight line across the coil spring, to help with realigning the new motor.
Use tool j-38864 connect it near outer part of coil sprint where it hooks to retainer or in a pinch use pounted vice grips at same location ensuring they are firmly locked on spring.
Force spring clockwise to disengage it from it's retainer point.
Pull spring slightly outward just enough to clear the retainer point and slowly let it uncoil counterclockwise.
Disconnect wire connector from right end of window motor.
Push the three plastic retainer points outward as you lift up on window motor to disengage from retainers careful not to break the plastic retainers comes out pretty easy
Install new motor into the plastic retainers, make sure it is fully seated.
Reconnect wire connector to new motor.
Use J38864 or vice grips to recoil spring, reseating it to retainer point as before.
Remove tape from window and test up/down switch.
Reseal vapor barrier in place as it was before.
Slide switch control back up through hole in door panel from where it mounts and slide door over the door handle.
Align retaining clips to holes and push them home with gentle raps of your hand start at the top and work downward on panel.
Replace the bolts in the arm rest and pop back in the controls.
Mar 04, 2011 | 2000 Pontiac Montana
Changing the window motor driver side
To change the window motor driver side, follow the steps below:
  1. remove 1 visible bolt left side of arm rest
  2. Pop out window switch/door lock/ mirror adjustment control panel with a screwdriver
  3. Use panel remover or just pull on interior panel to remove must slide it off of door handle
  4. Slide control switch panel down through hole you popped it out of
  5. Pull vapor barrier loose bottom right side to expose coiled spring and window motor
  6. Tape window in the up position using masking or package tape
  7. Mark a straight line across coil spring to make sure you can realign it when reinstall
  8. Use tool j-38864 connect it near outer part of coil sprint where it hooks to retainer or in a pinch use pointed vice grips at same location ensuring they are firmly locked on spring ( be very careful, I'm not responsible for any injury if you are not)
  9. Force spring clockwise to disengage it from it's retainer point
  10. Pull spring slightly outward just enough to clear the retainer point and slowly let it uncoil counterclockwise and let it sit there
  11. Disconnect wire connector from right end of window motor
  12. Use your hands and push 3 plastic retainer points outward as you lift up on window motor to disengage from retainers careful not to break the plastic retainers comes out pretty easy
  13. Install new motor into the plastic retainers, make sure filly seated ( lining up plastic Guides into holes in motor (3 points)
  14. Reconnect wire connector to new motor
  15. Use J38864 or vice grips to recoil spring, resit it to retainer point as before you have to be very careful in order not to hurt yourself
  16. Remove tape from window and test up/down switch ( key must be on)
  17. Reseal vapor barrier in place as it was prior to starting
  18. Slide switch control back up through hole in door panel from where it mounts
  19. Slide door over door handle
  20. Align retaining clips to holes and push them home with gentle raps of your hand start at the top and work downward on panel
  21. Replace both bolts in arm rest
  22. Pop window/door lock control panel back in place
That is how to change the window motor of the drivers side of a 2000 pontiac montana.
Take care and good luck
Jan 06, 2011 | 2000 Pontiac Montana
The thin plastic internal piece that is needed to open and close the trimmer of my Braun #9585 has broken. Where can I get a replacement.
The trimmer is broken. This is a common problem with this model and only an authorized Braun repair center can help you with this. There is one in Evanston, IL that can accept shavers from all over the US. Their phone number is 847-869-7755
Aug 18, 2010 | Braun Health & Beauty
Long hair trimmer wont push down
the switch/trimmer is broken inside and will need replaced. You will find the replacement item for model 8595 at shaveroutlet.com. see link below
http://shaveroutlet.com/braun-8995-8595-and-8795-body-housing-with-trimmer-p-684.html
May 20, 2010 | Braun Activator 8595 Electric Shaver
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
The on/off slider is stuck on won't slide to off position
The trimmer/switch is broken. You will need to replace it. You will find the components that you require at shaveroutlet.com. See link below
To replace the part you will need to remove the 'cap' that surrounds the cord hole on the bottom of the shaver by gently prying it off with a small flat screwdriver or similar object. Once removed, the side grips will easily pull off revealing 4 screws. Remove screws to seperate the front and back case. The inner parts simply lift out and you can put them into the new case
Mar 22, 2010 | Braun Activator 8595 Electric Shaver
Cannot switch from '1' to '2' to '3'
The problem is that the switch assembly is broken. You will need to replace it. It comes with the whole outer case of the shaver and is available at shaveroutlet.com. See link below.
Yo replace it, you will need to first remove the 'cap' on the bottom of the shaver. This is a piece of plastic that surround the hole on the bottom of the shaver where the cord plugs in. Gently pry it off with a small flat screwdriver or similar object. Once removed, the side grips will simply pull off revealing 4 screws on the back. Remove screws to remove the back cover. Then list out the internal components.
Reassemble in reverse order
Feb 15, 2010 | Braun Activator 8595 Electric Shaver
Pop up trimmer stopped working Remington R830
Make sure you are using the trimmer with the shaving heads on the shaver. With heads removed, the trimmer on the back will not work properly. If thats not the problem, the trimmer is broken or jammed. clen the blades really well with a toothbrush and rubbing alcohol. If they're jammed, this will probably free them up. If that doesnt do it, the trimmer is probably broken and that part is no longer available from Remington. If you really like this model, you can find a replacement at shaveroutlet.com
Jan 10, 2010 | Remington Health & Beauty
Braun Activator 8595 Electric Shaver Logo
1,586 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
