Question about Home Security
Need manual for moore-o-matic xx133 door opener
Garage door does not work automatically after bumping against car bumper when closing
SOURCE: Automatic Garage door reverses and automatically opens after closing
I had a similar problem and traced it back to the electric eye that makes sure there is nothing in the way of the door that would be crushed by it when it closes. Somehow, the receiving end was moved slightly. It was receiving enough light to start the door moving, but the shaking of the door as it came down, diminished the light enough that the door thought something was in the way and went back up. Once I aligned both the light transmitter and receiver, it started working again. Good luck to the rest of you.
Posted on Jan 19, 2008
Diamond E
  • 57 Answers
SOURCE: programming garage door opener
http://www.aaaremotes.com/linearx.html http://www.chamberlain-diy.com/pdfdocs/114A2504.pdf 1rst is to purchase the second is a manual index.
Posted on Sep 13, 2007
SOURCE: garage door opener troubleshooting
Try backing off door travel ajustment,
Posted on Apr 14, 2008
  • 244 Answers
SOURCE: GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Posted on Jan 15, 2009
  • 244 Answers
SOURCE: How to add additional garage door opener safety sensor
cant be done. put parking bumper on flor so you know you pulled in far enough. you are only one I know who installed parking laser. I don't. If customer isnt home when I install gdo, how do I aim laser. What about when they get new car. They want you back for free to adjust, No way.
Automatic Garage Door closes then Reopens and Won't Stay Closed
Check again to see if anything is blocking sensor(s).
May 23, 2016 | Building Materials
Why wont my 3 remotes (hand held & factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain drive
It could be that your door is binding on the way up and so it stops automatically. Try releasing the emergency pull cord and move the door up and down by hand to see if it is binding, probably near the bottom. The track may be misaligned or there could be something rubbing against the door.
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
When the door closes, it automatically reopens. There are no obstructions so that isn't the issue. If I disconnect the door and cycle the automatic is closes and then immediately reopens.
make sure that the auto matic reverse circuit light is being read correctly. they is a light extending a beam of infared light, you can't see it, to a reflector across the garage at the floor level at the garage opening. There should be an indicator light, usually green and red. Line up the light and reflector until the green light comes on.
Mar 08, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a craftsman garage door opener model 139.53674SRT2. It was working fine and we opened it and closed it twice today with no problem. The third time we opened it, it would not close. Both led...
The led blinking 5 times is the code for "RPM sensor or motor overload." The motor has an thermal switch which opens when the motor get hot from running too much. This automatically resets itself after about 15 minutes. This problem can also be caused when the door opens too far and the trolley jams against the bolt just in front of the motor unit. To correct this you need to loosen the chain enough to eliminate the tension against the trolley and then run the motor until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jul 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to switch back to automatic after manually close the garage d
mikey-moore's advice helped me figure out what to do but it's not exactly what I had to do. Manually open the garage door all the way. Then hit the automatic button you normally would use to open and close your garage door. The bracket slides back and locks into place. Hit the automatic button again and the garage door should automatically close.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
After opening, my automatic garage door creeps back down a bit
There is a sensitivity switch for both directions, open and close. If you access the garage door opener in the ceiling, you will see two adjustment screws for calibrating these. I would highly recommend following the instructions in your manual, as these are life safety adjustments! Your sensitivity for closing the door is adjusted to the positive. You just need to back it off a little. Place a 2x4 on the floor of the garage where the door comes down. and when the door hits the 2x4, it should automatically come back up. If not, you adjusted it too far. Hope this helps. and remember, check the manual for your specific adjustment procedures.
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
The garage door works when it wants to.
You have a problem with the safety eyes. Make sure a light is on on both eyes. If not, realign until both lights come on.
Jan 21, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Nov 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programming garage door opener
Sep 13, 2007 | Nintendo Game Boy Advance Console
Home Security Logo
661 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
