Question about Car Audio & Video
What is the code for the radio in a 2004 Kia pregio van
  • Car Audio & ... Master
  • 32,281 Answers
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Kia service centre andget them to enter this code for you.
Posted on Feb 25, 2012
4 Suggested Answers
SOURCE: have just started new job, got given kia pregio
You need to have your book with all your serial no's etc. Then phone Kia in your country (eg Kia Australia) and give them all the right info and they'll give you the code over the phone. You do not have to take out the stereo, and don't phone a local dealer as they will tell you this has to be done and will cost from $75 upwards.
Posted on Jan 16, 2011
  • 4869 Answers
SOURCE: i need a radio code for my kia pregio thanks.
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here  for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST A BRAND  NEW  QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
Otherwise try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Posted on Dec 12, 2009
Testimonial: "very quick to answer thank you."
techbuster
  • 5081 Answers
SOURCE: radio lost when new battery was inserted
Radio code is specific for each and every car. It is specific like anti theft code.
So you can get it by providing your VIN# and registration details in authorised suzuki dealership.Nobody else can provide you. If anybody can provide you that , then there is no meaning of security for your car.
Posted on May 10, 2010
Testimonial: "thankyou you have been very helpful."
How do I replacing the front injector pump seal on a 2004 kia pregio van?
u need a shop manual-haynes is a popular one--library has chilton volumes in the 600 isle
Jan 12, 2015 | Kia Cars & Trucks
Do you need to power bleed a clutch for a 2004 pregio kia van
please post to KIA , not honda.
but is the same.
attach power bleeded to MC
set 1-2PSI
open bleeder valve at slave, let it run till no bubble and close.
dont let MC run dry
no different than brakes.
Aug 01, 2013 | 1996 Honda Accord
Where do you find the air filter of a kia pregio van model 1997
At the end of the large air inlet hose to the engine inside a plastic air filter box.
Nov 04, 2012 | Kia Cars & Trucks
My kia pregio van ,diesel engine always overheat
i had that problem too, my mechanic suggested to change the original two(2) rows radiator to four(4) rows radiator, and it solved my problem
Jun 21, 2011 | Kia Sorento LX Cars & Trucks
How to change the globe to the headlight of my Kia Pregio GS 2005 van
To replace headlight bulb of kia pregio van: You only need Phillips screw driver and 10mm socket or open wrench. Open the hood, remove front grill with 4 phillips screw. This will give you room for your hand to pull out the headlight housing later on. Next is remove the signal light housing by unscrewing the phillips screw on top of the headlight housing then pull out the signal light housing and remove the bulb. You will see 2 pcs 10mm bolts on the side which hold the headlight. Loosened and remove the bolts on headlight holder then pull the headlight sideward. Remove power supply socket before removing it completely from the van. Remove bulb socket, spring clip, and busted bulb and replace with new one. Reassemble the disassembled parts in reverse order. That's it, will take you only 10 minutes.
May 27, 2011 | Kia Rio Cars & Trucks
Have just started new job, got given kia pregio van, radio not working, (need code), do i look around car for code eg ash tray,glove box, or do i have to contact dealer with vin number etc? many thx , ...
Dec 17, 2010 | Car Audio & Video
Radio lost when new battery was inserted
May 10, 2010 | Audiovox Car Audio & Video
Car Audio & Video Logo
248 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
