SOURCE: Water won't spay out of the nozzels under front plastic
There are 6 screw, 3 on each side, then the top will come off. When you put it back on, make sure the piston is attached to the bottom of the smart mix knob and that the knob is in the water setting.
SOURCE: Bissel Little Green Spray Motor
Motor was seized. Probably from lack of use combined with the moisture involved with such a device. I loosened the motor with a pliers, gave it a small shot of wd-40, and off we go. Works fine.
SOURCE: will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
SOURCE: my little green machine won't spray the solution but it will pick
The Pumps on these go bad after a couple of months. They rust and will
sometimes spray and other times not then eventually not work at all. If
your a handy man pull the top off it and remove the pump motor and
replace it yourself. The part number is 603-5029 you can put this number
in google shipping and get it to your door for about $15 and replace it
yourself or have a friend do it. Ebay has tons of them once again just
put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
