Question about Nintendo Wii Console
Wii console will not power up - Nintendo Wii Console
Is there a master reset on the wii
Instructions
    • 1
      Locate the "reset" button on the front of the Wii console. Hold it down for a few seconds to reset the device.
    • 2
      Wait for the home screen to appear, then hold down the "power" button on the front of the Wii until the power light turns red and the Wii shuts down.
    • 3
      Unplug the Wii's power supply from the wall outlet or power strip.
    • 4
      Leave the Wii console unplugged for at least five minutes. Reconnect the power supply and press the power button to turn the Wii back on and complete the hard reset.
Nov 06, 2011 | Nintendo Wii Console
Our wii has been boxed away awhile we cant get it to reconize our emotes can help
Here is a step by step instruction on Syncing your Wii remotes to you console!!http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Standard Mode Synchronization
Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Sep 12, 2011 | Nintendo Wii Console
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
These sync settings will be saved even after the console is turned off.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.
Open the SD Card slot cover on the front of the Wii console.
Remove the Battery Cover on the bottom of the Wii Balance Board.
Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
Press and release the SYNC button on the console while the Power LED on the board is still blinking.
The Power LED will stop blinking and light steadily once the synchronization is complete.
Mar 16, 2011 | Nintendo Wii Console
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
Wii console will not power on. is there anyway to
Hi there, you could try the following:
  1. Try unplugging Wii from the power for a full 2 minutes, plug back in and power up and test (This resets the Power Adapter).
  2. If this does not resolve it then it may need to be repaired so contact Nintendo here.
Please see here for for information on Power issues with the Wii.
Cheers
Apr 03, 2010 | Nintendo Wii Console
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
The Wii will not turn on.
Unplug wii power cord from wii and wall for 5 minutes
Nov 25, 2009 | Nintendo Wii Console
My wii will not turn on now
Is the power button on the Wii console lit (orange)? If not, then your Wii doesn't have power. If yes, try turning it on with the power button on the console (instead of using a Wiimote).
Aug 04, 2009 | Nintendo Wii Console
Synching wii fit causes wii console to no longer power up
1, Turn off and unplug your wii console for a few minutes
2,Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
* Then remove the battery cover from the wii remote, inside you will see another red button.
* Press and release the red button, the blue lights on the remote will start blinking.
* Quickly press and release the red sync button on the wii console.
* The remote will stop blinking and it should now be synced.
then try syncing your wii fit bored
Dec 28, 2008 | Nintendo Wii Console
Wii not powering off
You have to hold the power button down on the Wii console for many seconds before it will power off completely. Try it for more than 5 seconds.
Nov 29, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
13 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
