Question about Vacuums
Need drive wheels for my eureka selfpropelled model 5060F
Need drive wheels for my older eureka selfprolled upright model number is 5060F called a bunch of warehouses eureka sears and had no luck
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Motor replacement for upright Eureka 4467av
Part # is 60261-11, but Eureka has it No Longer Available. But check with a vacuum repair shop, they should be able to order one for you, but they cost around $80 or so.
Posted on Feb 06, 2008
MATRIX_MMX
  • 209 Answers
SOURCE: eureka upright vac. no suction
Dear wymanwong
Righteo, your problem is not exactly all that straight forward as i dont have a great deal of information to go on with regards to this type of issue and this make/ model of vendored appliance, so I will begin by explaining how the typical vacumn cleaner functions (in relation to your issue) and what can cause a fault of this kind.
The vacumn cleaner overall (unless is a liquid cleaner as well as a conventional dry suction unit) has the function of providing suction into either a chamber or bag which is either filtered or emptied, and the effects of loosing suction usually are effected by faults within filters, or directly through the motor that is normally powered through 240V~ (AC) within the UK or
115~ (AC) USA. Suction can also be lost through blocked exhaust outlets through the vacumn unit and also through any perforations or tears to a bag/ container that is used in order to maintain constant suction and storage of particles/ vacumned waste.
Now to investigate the fault you have in regards to loss of suction within your unit.
Firstly You should query the suction motor and the copper windings as these are both electronic and mechanical components that can be affected not only by general wear and tear, but also by various ingressions (such as water and liquids). Also heat can play a major role here, as motors can spin up to a large amount of revolutions per minute (RPM) and this will cause heat build up, add this to the fact that the windings inside most electric motors are made of copper, and you can quite easily discover that the motor will "burn out" as copper will break down at somewhat lower temperatures than other electronic components (this is also more likely as the casing of a DC/ AC motor is contained within a steel structure which is a good store/ conductor of heat).
The other factor that should be considered with vacummn failures is also associated with exhaust impedances. In otherwords, if outlets and filter channels are blocked, then overloads through the motor wiill be likely and the entire system may cease altogether.
In addition to this, investigations of the power supply and any power transformers within the unit should also be queried, along with any rectifiers (used for converting an AC signal to a DC signal for use with DC motors if necessary), as faults with these can occour even over short periods of time.
If queriying these components have returned no results to the fault, then there is always the option of attaing the service sheets for your appliance from the manufacturer/ vendor of your appliance. The best thing to do in this case is either to go to http://www.google.com or to the website that is listed for your manufacturer/ vendor. Now if google if your option, then there are a few keywords which will assist in your search for your service sheets and they are to simply either type your appliance name followed by the words "service sheet" or "repair manual" In addition to this, you can always contact the manufacturer/ vendor of your appliance directly by telephone and delegate with them in order to request user manuals and servicing guidelines, and given the fact that you have a small appliance, if you mention that there is a possibility you would order any spare parts through them, then i really cannot see a reason why they would decline offering you the servicing guidelines/ manuals at a low cost.
Now there are other things here that can be investigated, but in order for me to dfo this i will need full details of your appliance model number and maufacture code, along with full details of the fault, as accurate as possible. Also photographs of either the machine or any/ all of the internal components will greatly help as direct visuals will aide not only in the identification of your make/ vendor model, but also may give a visual clue of what could be defective within your appliance (for example scortch marks on the wiring that supplies your vacumn motor etc) But any pictures supplied will need to be of a high resolution and quality.
Well I do hope that this brief explanation will provide enough information for a fixya or even a total unit overhaul in the most cost effective manner, in addition to this i do hope that i will hear from you in the somewhat near future as so i can find out more about your fault and indeed if you have managed to resolve it elsewhere (and even how this was done).
I am here most days and nights and any contact to and from me will ensure that I endeavour to resolve your technical issue in the most appropriate way for you.
In the meantime, i do hope you take care, and look forward to hearing from you soon
yours sincerely
Oz
Here on demand for all your technical needs
Posted on Apr 14, 2008
What is the replacement belt number?
Shop for Eureka Vacuums What is... on Google
Eureka® Replacement...
$2.89
Staples Eureka Upright Vacuum Clea...
$5.99
Eureka Eureka Hand Vac Belt
$2.49
Eureka Eureka R Type Replacement...
$5.99
Bed Bath & B...
(4) Eureka AS1104 Drive Belt
$3.49
Google Trusted StoreeVacuum... Search Results
    Belts - Eureka
    www.eureka.com/en-US/Vacuums/Accessories/Belts/
    EurekaWith high-quality vacuum cleaner belts from Eureka, you can get better performance from your ... For optimum performance replace belts every 12 months.
    Eureka Replacement Belt for Upright Vacuum ... - Walmar
Jan 19, 2016 | Eureka Vacuums
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
I need part number of front wheel assembly...
part number for the wheels [you'll need to order two] 74818a-119n, the axle is part no. 71478 - available at sears 1-800-4myhome
Aug 17, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Looking for the instruction manual for the Eureka Altima 2993AV HEPA Upright Bagless Vacuum Cleaner
Go to http://www.eureka.com/service/manuals/80244.pdf this is a direct link to the owners guide for your model or you can call customer service at 800-282-2886 and request a hard copy
Jul 02, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Handle from my Eureka Uno 2999 AVZ broke off
try a company called cds they r in the midlands but they courier parts out 2u dont have their no 2 hand u will need the model number try the web marting
Mar 17, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
I need hepa filter specification for eureka upright mega boss.it is not bagless.
http://www.eureka.com/servlet/FindOwnersGuide
"You will find your model number on a metallic silver-colored rating plate. It’s usually located on the back or bottom of the cleaner. Here is an example of a rating plate: You will find your model number on a metallic silver-colored rating plate. It’s usually located on the back or bottom of the cleaner."
"Not all accessories, supplies, owner's guides or Eureka program details are available online. If you can't find what you're looking for, you can call 1-800-282-2886 for assistance. Our Service Representatives are available Monday through Friday, 8 a.m. to 7:30 p.m. Central Time, and Saturday and Sunday, 10 a.m. to 6:30 p.m. Central Time. Our Service Representatives will need your vacuum's model number, so please have it ready when you call."
Feb 25, 2009 | Eureka Mega Boss 4460DT Vacuum
I own a Eureka Optima 437 and one of the rear wheels are broken and cannot find parts for this. Where can I find parts for real wheel?
Sorry, your best bet is to call Eureka or Electrolux. If they can't provide you a part start looking on cragslist or Ebay.
Jan 20, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Filter
Eureka Altima Upright Vacuum Model #2996AVS
Where is it located and where can I get it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can check your local vacuum cleaner dealer in the yellow pages in your area and they will either have it in stock or they can order it for you or call the Eureka factory phone number listed below… generally you can find one or the other.
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Apr 16, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
61 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
