Question about Sewing Machines
I have a sewing machine that says zigzag model number 550,what brand is it?
bargainbox
  • 1388 Answers
SOURCE: HUSKY DELUXE SEWING MACHINE
Your local Husky dealer or via their head office in your country ought to be helpful unless they are out of print.........if so, ......Try sewusa.com or sew4less.com
Posted on Jun 02, 2008
SOURCE: i need to find out how to load thread into a white heavy duty sewing machine model number 1866
actually they dont NOT TO THE WHITE 1886, I whoever is asking, I have the same problem. My own mother, and grandmother who have sown ALL their lives, who make clothes, etc. etc. CANNOT figure out for the life of us all, how to get that thing to load the thread., We get it through the needle, and underneath, And it looks normal, Its what you would do on a normal machine. But when you start, Is when it messes up. I think, they put up for sale because of this error
Posted on Aug 22, 2008
kent581
  • 87 Answers
SOURCE: FEW STITCHES DROP IN BOBBIN
Dropped stitches troubleshooting:
1>change to a new proper needle (proper needle means quilting needles for free motion, stretch needle for knits, leather needle for leather, microtex needle for micro fabrics.....etc.) of proper size. Most sewers never need a needle smaller then an 80/12 when sewing. Smaller needles bend more easily causing more problems.
2>If a new needle doesn’t fix the problem, remove parts from bobbin case area (as best as easily allowable) and clean out all the lint thoroughly, and oil with 2-3 drops of oil where friction occurs (turn hand wheel and look for rubbing)
3>If still skipping, try a different spool of thread (Yes, thread can caused skipped stitches, not common but I see it).
4>If you haven’t solved it yet, sounds like you could need to make a lower level adjustment like hook timing.
Hook Timing:
To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher
Posted on Mar 21, 2009
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
  • 980 Answers
SOURCE: Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Posted on Nov 06, 2009
My sewing machine only sews zigzag stitches never a straight stitch. Why?
We need to know the make & model machine.
If it is an older mechanical Kenmore, more than likely it is seizing due to old oil turning to glue inside the machine. Unfortunately, these old machines were made too well as the manufacturers never anticipated the machines would be around for 50 years. However, as mechanical machines they do need regular cleaning and oiling with a good quality oil, ie liquid Tri-Flow Synthetic Lube or "good quality" sewing machine oil.
Either the stitch width regulator is broken or stuck or the mechanism that drives the needle bar is stuck. With plenty of time, patience, elbow-grease & Tri-Flow, your sewing machine will probably be sewing like new.
I've used the following method to free up some great old mechanical machines and they operate like new again:
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
Also, be sure to change the needle frequently, ie every 8-16 hours of use. Most sewing issues can be resolved with a new needle.
May 05, 2017 | Sewing Machines
Value of a White Brand Sewing Machine, model 465, serial number 7866
Value is too subjective to estimate. There are many things that go into value, ie working condition, physical condition, rarity, accessories included, where it's located...
You can search for recent sales or current listings that may give you some idea of your machine's value.
http://www.quiltingboard.com/vintage-antique-machine-enthusiasts-f22/white-model-465-made-when-t263321.html
http://www.ebay.com/itm/Industrial-Strength-White-465-ZigZag-Sewing-Machine-/120735651046
https://www.youtube.com/watch?v=_Hjk85uvhMI
Apr 20, 2017 | Sewing Machines
Why is my White 1866 dropping stitches not picking up the bobbin thread when I am doing zigzag stitches?
Be sure you are using a brand new needle that is compatible with the thread and fabric you are sewing. Otherwise, your machine is most likely a bit out of time. Search for sewing machine timing or take it for service.
Feb 25, 2017 | Sewing Machines
Hi! I'm looking for a manual for a vintage Morse 550 zig-zag sewing machine. Need help with tension assembly.
manual for a vintage Morse 550 zig-zag Kathleen, Check the attached links,manuals and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Morse 550 zig zag manual Google Search
Morse 4300 Zig Zag Sewing Machine Instruction Manual Fotomatic III
Morse Pushbutton ZigZag Sewing Machine Threading Diagram
http://www.sewusa.com/Sewing_Machine_Manuals/Morse_Sewing_Machines.htm
Mar 31, 2016 | Sewing Machines
Machine is 30+ yrs old and tension settings .. There are 3.. Are all screwed up so stiches are not even, tight or inform...can someone help me know the normal setting and how to adjust for zigzag...
You haven't mentioned a brand or model number. Go to this YouTube page for general repairs and setting up zig zag.
https://www.youtube.com/results?search_query=how+to+adjust+seetings+on+sew+machine+for+zig+zag
But in any event, go to the manufacturer's website and go to the support page. Download the user manual, if they still have them, for your model. Settings should be located within manual.
Mar 04, 2015 | Sewing Machines
I NEED USER MANUAL NFOR 457G135 ZIGZAG SINGER MACHINE
Suggest you search thru google by its brand & model number, hope you can pick it from there.
Oct 24, 2013 | Singer Sewing Machines
Empisal celebrity 550 manual- My Empial Celebrity 550 stopped its zigzag function.Please help?
contact a1sewingmachines.com and ask them about a manual
it's possible that the zig zag function has stopped is the gear or cam may be so worn or broken that the machine needs to be checked to see if it need to be replaced..
Sep 10, 2013 | Sewing Machines
Can this machine do zigzags?
The Sew Dlite 11401 shown on Amazon here, http://www.amazon.com/DLite-Supreme-Portable-Sewing-Machine/dp/B0006BDG8Q , does not do zigzags. It only does straight stitches. There are similar models that have a stitch width lever. Those do zigzag stitches and straight stitch when in the zero width mode.
I hope this helps.
Aug 25, 2013 | Sew D'Lite 11401 Mechanical Sewing Machine
Singer Touch and Sew Model 648 will not zigzag
There is an arm in the head that does the zig zag movement and attaches to the needle bar with a pin. If that isn't connected zig zag won't work at all.
Jan 19, 2013 | Sewing Machines
Sewing Machines Logo
65 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
