Question about Logitech Notebook Cooling Pad N100 Model 939-000119 CPU Fan
How do I disassemble my logitech cooling pad for cleaning?
Fan is full of dust that I can't get to.
    New Friend:
Hi, I just did clean my logitech pad without any sratch. Here is how I did dissemble it.
There are 10 screws. 3 at the back of the pad, which can be removed very easy. Another 7 are under the shiny plastic part with whole for the airflow in front of the pad. It is easy to remove it. I used a wrapping ribbon (the ordinary for wrapping presents) and put it through the wholes in the top middle part of the cover, in the way you end up holding both ends of the ribbon. And gently pull the cover apart of the pad. It goes quite easy. Then remove the 7 screws (2 are hidden in the wholes with the white plastics)...and you can start cleaning. I did not remove the fen part itself. Its easy to clean it with an old toothbrush.
I hope this helps.
Posted on May 19, 2013
2 Suggested Answers
Crenshow
  • 250 Answers
SOURCE: My logitech cooling station stopped working! The
Hi, I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by
warranty terms.
If you are not under warranty you still can contact them as I know for instance in Europe they can offer you some
good deal on nowadays products for out of warranty people.
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Posted on Jun 15, 2010
Cleaning the fan
I use compressed air to clean out the heat sink fins and fan. This is less thorough than pulling these items and cleaning them, as that usually requires a full disassembly to access these items - but it ususally suffices if you do this on a regular basis (once every month or two).
If full disassembly is required, Google "<My laptop model> disassembly" and you will most likely find several YouTube videos or step-by-step instructions showing you the process.
One caution - NEVER vacuum the interior of a computer. Doing so can produce static electricity that can damage/destroy internal components.
Hope this helps...
Jan 03, 2013 | Computers & Internet
My logitech N100 cooling pad has stopped working
first check the connetions at both ends of your cooling pad make sure the connection into your laptop is securely seated and its not faulty
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb pad but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Jun 01, 2011 | Logitech Inc 939-000119 N100 Cooling Pad...
Getting overheated and then shutdown latop immediately, sometimes it works for hr and soemtiems it turns down in 10mins. Mins is acer 4730z laptop.
Follow this steps to avoid overheating:
-Don't use your laptop in full sunlight for extended periods
-Don't leave the laptop in a closed car on a sunny day
-Don't place the laptop on or near extreme heat sources, such as radiators, hot air vents
-Turn off your laptop before putting it in your carry bag
-Turn off your laptop when not in use for a long period
-Work on an even surface as much as possible, not on your lap!
-Clean the air vents in your laptop regularly by using a can of compressed air
-Get more space under your computer by propping it up on something when it's on a desk
-Consider purchasing a laptop cooling pad
-Consider purchasing an external fan
To clean your laptop's cooling system:
-Shut down the laptop ie do not leave it suspended, sleeping or hibernating.
-Unplug all cables from the unit and remove the battery pack
-Get a can of compressed air and blow it into all vents around your computer - this should clear out any dust and hair.
-Do Not use a vacuum cleaner.
Dec 12, 2010 | Acer Aspire 4730-4947 Notebook
Iam using HP Desktop D530 when i open some programmes but processor fan runs so fast and loud 2 gb ram in my pc and hard disk is 20 gb how can i reduce noice of fan ?
To reduce the fan noise, open the PC Case and clean the fan. Also, proper ventilation keeps the system cool and the fan runs at lower speed.
Hope this helps!
CreativeTECH
Dec 11, 2010 | HP Compaq d530 Small Form Factor PC...
My acer aspire 5315 shuts off suddenly and won't restart till it wants to. I replaced the battery, no difference....what's wrong?
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced
Oct 22, 2010 | Acer Computers & Internet
Very noisy fan
Make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Oct 18, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hp dv6810 keeps overheating and turning off fan is ver noisey
Oct 13, 2010 | Computers & Internet
Hpa pavillion dv4-1220us has very high fan nosie and overheating problem
Sep 29, 2010 | HP NB199UA Pavilion Notebook
Laptop is producing too much heat than usual
Sep 23, 2010 | HP Compaq 6735s Notebook
My old Sharp Actius UM32W laptop powers off after about 3 minutes and the number pad "N" indicator light flashes. How do I fix this?
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 19, 2010 | Sharp Actius UM32W Notebook
Logitech Notebook Cooling Pad N100 Model 939-000119 CPU Fan Logo
3,352 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
