Question about TruTech PVS12701 Portable DVD Player
Trutech DVD player
No picture shows, the screen goes white.  sound is fine.  any advice.
5 Suggested Answers
SOURCE: Customer service number for Trutech
I too purchased TV on Black Friday from target in 2006 and w/in the last month the picture went..The sound works, but no picture..cust service tel #:888-252-6252..I tried to call but was on hold so long...I'm actually on hold again...If you happen to figure out what the problem is, please e-mail with resolution..TV isn't even a year old..Can't find the warrenty...
jdinap@comcast.net
Posted on Nov 21, 2007
Benimur
  • 6966 Answers
SOURCE: Battery Charger for Trutech Portabel DVD player
As have been posted in a post of similar concern...
You can try calling Target Customer Service 1.800.440.0680 and inquire cost & availability of the charger for the TruTech PVS12701.
Additionally, you may want to contact the manufacturer direct.
ALCO Electronics, Inc.
8392 Six Forks Rd., Suite 104, Raleigh, NC 27615,
(800) 252-6123)
Should you need direct Customer Support, please try here.
Alternately, you can just look for an AC adapter/charger that has the following specs:
Input Voltage - your country's standard AC mains;
Output Voltage - 12VDC
Output Current - at least 1.5 Amp (the higher the better)
Connector - one that will fit and match the polarity of the TruTech PVS12701. (am guessing crown type center positive, pls confirm with the store. It may also help to bring along the unit when doing the purchase over the counter).
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 13, 2008
SOURCE: trutech t600-d dvd player
Only a temporary solution....
Target sells a scam with their Trutech brand, this entire line deserves a recall, nobody is getting support or refunds. NOTHING. Target deserves a class action suit against them.
In the time-being, your DVD player probably still can play movies, just that the drawer gets stuck. What is happening is, the mechanism that raises the DVD to be scanned when the disc is in doesn't lower properly so when the drawer is supposed to eject, it is held back. You can manually eject this.
The cheap flip-down door is flexible so when you press the center of it, the outside edges become bowed and can be pulled down with a fingernail. Under the drawer (you may need some light to see for the first time), about 1/2" from the left inside, there is a black plastic wheel. Using a paperclip, you can catch the "teeth" on this wheel and turn it counter-clockwise (from left to right) and this will lower the mechanism and likely your tray will automatically eject.
You might be surprised that after this, your tray will open and close fine consecutively by hitting the eject button. But keep in mind, the problem is the mechanism that raises the DVD to be read is what holds back the eject from working.
Do yourself a favor and scream at Target. Make yourself heard, everyone is having problems with this line.
Posted on Jan 21, 2008
  • 3 Answers
SOURCE: Mitsubishi WS-65807 + PS3 1080i Screen goes blank when bright white displayed
Go to PS3 / Display settings. Set superbright OFF, even if you don't have HDMI. Set Cross Color Reduction to OFF. Set Display to only one resolution, not all of them as you probably have it now. Set it ot the highest possible resolution and uncheck all other boxes. The 480i is always on by default. The issue, which was very annoying, was fixed for me. I have a mitsubishi 65 inch RP that is pretty bright on daytime/sunlight scenes, so I never thought it was the PS3, but only whet the PS3 was used did this occur. I scanned this site via google to find that nobody else appeared to have resolved this. So after some changes and testing this solution worked for me. Enjoy! - Dave Walz
P.S. I think the only real fix was to set just one display resolution, but I am now watching a movie and am not going to stop it to find out. :) That's for whomever follows this posting to find out for themselves. Either way, this is working great.
Posted on Apr 26, 2009
  • 33 Answers
SOURCE: trutech LCD HDTV has sound but only white screen
lcd cable came off or is loose. located on rear of screen and attached to main board also.
Posted on Oct 08, 2009
Hooked up dvd player to tv but no picture
Select Source button from your tv remote keep in AV mode than cheked if you have conected with yellow/red/white rca wire
Jan 21, 2010 | TruTech PM1919BXA1 19 in. LCD TV
I have a trutech LMD5702RT portable duel screen dvd player the cable is broke that goes in 2nd screen we get sound but no picture. Can I buy just that cable
If its the red white and blue AV cable on both ends yes you can. If its a red white and blue AV on one end and a audio looking jack on the other end you can too. They sell all those cords at Radio shack or most electronic stores.
Jan 09, 2010 | TruTech LMD-5702RT Portable DVD Player
Monitor #2 has sound, no picture
A/V cable is broke. I'm trying to find one also with little luck
Jun 16, 2009 | Televison & Video
Blank screen no picture
connection between the dvd output and screen has broke link somewere. pull it apart and check it out
Jun 05, 2009 | Philips Magnavox DVD/VCR Dual Player
No picture on one screen
Sounds like the screen went bad/went out. Lcd's going all white signal a need for a new panel. Sorrry, the screen needs to be replaced. It's beyond repair. needs new screen.
May 14, 2009 | TruTech PVS12701 Portable DVD Player
Trutech dual dvd portable - second monitor does not show picture
i think it's corroded,rusted ,i mean rusted.clean it or replace the terminal or plug.
May 08, 2009 | TruTech PVS12701 Portable DVD Player
Trying to hook PS2 up
u cant play them on it its a dvd player
Dec 12, 2008 | TruTech PVS12701 Portable DVD Player
Screen does not show picture, distorted image
If you go to 1800customersupport.com it has some good info. Alco Electronics is the maker.
Oct 04, 2008 | TruTech PVS12701 Portable DVD Player
TruTech DVD/VCR combo unit - DVD works not the VCR
I need to know your connection "tree" i e your chain of components and how they are wired...accordianman
Dec 26, 2007 | TruTech TT320
TruTech PVS12701 Portable DVD Player Logo
32 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
