Question about RTO Pit Bikes
My pitbike starts but when u give it throttle it cuts out, its spittin petrol out ov where filter, bit
2 Suggested Answers
SOURCE: my pitbike starts but when
did u tryand clean the carb and air filter if that dont work try and take the bowl off the bottom of the carb and see if the little pin for the floats are stickin and clean everything while u r there and see how that work should fix the prob
Posted on Oct 30, 2012
It keeps cutting out when i try to give it gas and ive already changed plugs and cleaned air filter and drained the carbs
Hi, just a couple of tips.
Check that there is no water in the petrol, drain the carburetor float chamber in to a glass and check for water.If you find any then you will need to drain the tank.
If you find no water, then take the carb off and check the accelerator pump does inf act pump extra petrol when you operate the throttle lever.
While you have the carb removed it would make sense to strip it down and clean all the jets with High Pressure air.
Also check visually that the needle rise when you open the throttle!
Jul 29, 2014 | Motorcycles
Tip
How to bump start a 110cc pitbike or 125cc pitbike
at first push your bike to a hill (dosnt matter how big or small)
remember where you can put it into second gear hold the cluch in and push down the hill and let out the cluch and jump as soon as it bites then it should fire up same as a car but harder on a pit bike as you got too much throttle you will flip it and gotta do it all again haha hope this was helpfull
if it still doesnt fire up then you have a problem with your bike
IMPORTANT........................................................................
1. make sure the petrol is on and the bike isnt flodded
2. make sure not too much throttle or it could be dangerous and if you do flip it lose go straight away
on Dec 06, 2009 | Exercise & Fitness
Why my pitbike wont start or cuts out
Yep, clogged fuel filter, dirty carb. ????
Mar 24, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
Sep 18, 2011 | RTO Pit Bikes
2001 r1 not been run for 14 months started it up not responding like it should.emptied tank n put fresh petrol in seems to respond better higher up the revs but wont tick over getting a bit ov back fire.
Try cleaning out your carb, Petrol starts to form into a jelly after 3 to 4 weeks if you dont turn the engine over. Your carb is situated under your petrol tank. Hope this helps
Jun 22, 2010 | 2001 Yamaha YZF-R1
My 110 bike is slower than others i no on
adding a performance exhaust system to most motorcycles will boost horsepower 3 to 7%. If the motorcycle is carburated, a larger jet and a high flow breather (filter) will help to gain the maximum.
Sep 21, 2009 | Pit SSR 110CC Pro Beginner Bike
Pitbike cuts out after a few seconds,
mate you have the idle screw then there will be a mixture screw the mixture screw is the small screw on the carb unscrew it 1/4 of turns at time and see if it improves also you probz got water in the filter
Aug 25, 2009 | 1994 Bimota YB 9 SR
Mcculloch strimmer/brush cutter - cuts out when throttle opened
Hi sounds like it could need a diaphram kit in the carby if it has mixture screws one markedl for low speed and one marked h for high speed you can try winding out the low speed screw a bit but if that does not work it will definatly need a kit.
Jul 25, 2009 | Garden
I have a 1999 zr2,when you give it cas under a
You didn't say if there was an engine light on. I'd check the t.p.s. throttle position sensor. It could be a jumped timing belt,based on the year , it's got milelage.
Jun 21, 2009 | 1999 Ford Escort
Hard starting when cold
try starting it on half choke if u open the throttle qarter ov a turn thn start it but litteraly 2 seconds after pressing thth button with the throttle open remember let go ov the throttle but keep ur finger on the starter button and wen she dus start just let her tik over 4 a cuple ov seconds thers a nak to it
May 12, 2009 | 2001 Yamaha SR 400
RTO Pit Bikes Logo
62 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
