Question about GPS
Manual pkc0pb peak pkc0pb installation manual
What does the flashing FL mean?
When the Jump-Starter is fully charged, the display will read FL. Disconnect the AC extension cord from the 110/120-volt AC outlet, and then disconnect it from the Jump-Starter AC charging plug. http://www.carid.com/images/peak/info/pdfs/pkc0j6-manual.pdf
Mar 29, 2015 | 600 AMP Jump Starter
Where can I get a manual for a Peak Power Station 450
Just Google the brand name & model and then select the correct manual.
Feb 21, 2015 | Vehicle Parts & Accessories
Where can I get a Manual for jump-starter 300
Battery Jump-Starter 300TM - All Power Supply
allpowersupply.com/Productlib/manual-PKC0AO.pdf
Translate this page Conserve este Manual del Propietario para referencia futura. P/N XXXXX, 3/09. 1 . TM. Battery Jump-Starter. 300TM. Model No.: PKC0AO. Owner's Manual.
Jul 24, 2014 | Peak Compact Battery Jump Starter 300 For...
How can i get a user manual for my Peak
I would search for the manufacturer and contact them directly or search for the model number online.
Jun 28, 2014 | PEAK 5" GPS PKC0PC
Off peak hot water not heating!!! :(
The Economy 7 can control different types heater. Some heaters do not have off-peak ... but you can solve problem..
Copy following link:
http://waterheatertimer.org/pdf/QE7-INSTRUCTION.pdf
If timer is wired to two different elements, then the night rate element or off-peak element might be burned out. Test element with multimeter.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Also this timer is wired so either Off-peak is getting power or Boost is getting power, but not both at same time.
If heater has off-peak element, then there will be a wire connected to terminal 5, going to heating unit.
If there is no wire on terminal 5, then there is no off-peak element, or wiring has not been connected. However you can change the timer function by moving wire on terminal 4 to terminal 5. Then only the off-peak timer function will operate, and not the boost.
You can also fool the timer, by setting time clock differently. Instead of setting timer for current time, rotate the dial and fudge current time by 10-12 hours so water heater thinks it's time for boost, but the actual time is during off-peak hours.
If terminals 4 and 5 both have wires, then either the element is burned out, or the timer has malfunctioned. Again, you can fool the timer by setting current time differently, and solve problem.
Apr 26, 2013 | Water Heaters
Creda storage heater manual
I'm not a heating expert, but according to the information I could find, Economy 7 utilizes cheap electricty at night, during off-peak hours (7 hours) between midnight and 7AM. Economy 7 costs about 4p per unit compared to peak electricity, which is about 10 to 15p per unit. If you do not have Economy 7, you can request it FREE of charge from your electricity provider. You will either have one meter with two readings or two separate meters. A two tariff electric meter will record the electricity used during off peak times, so it can be billed, separately, at a lower rate. If you have two meters, one meter controls on peak daytime electricity and the other controls your night time economy 7 electricity.
I would need to know what model Creda heater you have installed in order to determine how energy efficient it may be. I also will need the model so I can determine operating instructions. If you need further assistance, please post back and let me know. I hope this helps.
Nov 15, 2011 | Heating & Cooling
I need more transmission range for free
A lot of people will say that you need to peak and tune the radio to get more range. And it will, but what it really comes down to is your antenna system.
Even with the best peak and tune, if you don't have a good antenna system, it won't do you any good.
You need to make sure the antenna is a good match. If you don't know what that means, then you should refer to your manual on SWR. The antenna has to be tuned so that transmit power does not get reflected back into the radio. If that is happening, all of the RF power is not leaving the antenna, and you are not getting out as good as you can.
Once you have a good antenna system, then you can worry about peak and tuning. But for a peak and tune, I charge.
Sep 04, 2010 | Cobra 19 Ultra II CB Radio
Mtx audio 4252 amplifier
Hello freshman_fox,
63 watts X 2 @ 4-ohms.
125 watts X 2 @ 2-ohms
250 watts X 1 @ 4-ohms bridged
Since no power rating is given @ 2-ohms in bridged mode, it means that the amp is only stable to 4-ohms.
The manual does not specify a peak power, but since RMS is about 70.7 of peak, that makes it 353.5 watts.
You can download the manual from here. Hope this helps.
Jul 10, 2009 | Car Audio & Video
GPS Logo
108 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
