Question about Pioneer Audio Players & Recorders
My pre 1975 Pioneer amp is static sounding in both channels
2 Suggested Answers
  • 5 Answers
SOURCE: Pioneer SX-950
use a cable tester for the wires that are connecting to the unit and you'll find the faulty wire that is bad.....good luck
Posted on Dec 20, 2008
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
How do I connect my bose equalizer to my pioneer amplifier
The manual is at Bose.com.
In any question regarding connections the exact models of all parts in the scenario should be defined.
"Pioneer amplifier" is not unique nor revealing. Integrated amplifer? Power amp? Tape Loops available? Pre-Outs? What's involved as a preamp?
The key thing to know is that any amplifier channels driving 901's must not drive other speakers as the Active EQ severely modifies the Line Level source input. If the EQ (or any sound processor) is used in a Tape Loop on a modern multichannel digital-audio-capable AVR, ONLY 2-channel analog sources will function when the Tape Loop is engaged; and all downstream speakers will be affected by the processing. That's par for the AVR course.
Bose 901 use in multichannel applications (which I have) will require access to Pre-Amp outputs for the chosen channels (likely the Front) and you will need to get a separate amp for the 901's, placing the EQ in series with the chosen amplifier. I currently drive mine with a Carver MT-200T.
Sep 20, 2011 | Bose 901 EQ1915 Home Equalizer
How to wire Denon AVR 5600 as a separate amplifier in an existing system with a Pioneer SC-57
Do you mean for just 2-channel or what?
The Denon doesn't care what's upstream of it. CD players, other receivers, whatever. The Pioneer has analog pre-outs so you can slave any amps analog input(s) (except PHONO) to any channel(s) on the Pioneer.
Sep 13, 2011 | ATI AT2505 5-Channel Amplifier
My Pioneer PL-990 Turntable only outputs sound through the white wire. Only a quiet buzz comes through the red wire.
The red wire is the right channel, so going back to your amp, get a single phono plug with with the wire exposed, so you can touch the wire. Then remove the turntable connections. With the amp on plug the the lose wire plug into each channel and check if the sound on the right is still low. If it is then there's a problem with the magnetic cartridge pre-amp inside the amp. They are often located near the phono socket on a seperate PC board, but if not just follow the red wire to the main board. Chances are it will be an IC that's failed.
If it has a strong buzz at the back of the amp. Then I should replace the wire between the turntable and the amp. Or the right phono plug that connects to the amp.
Nov 13, 2010 | Pioneer PL-990 Turntable
I have static coming out of the speakers. One speaker appears to be not working the other just has static.
It must be checked after opening if the noise is generated from the output of the sound signal process of the TV.
You will need to use a audio signal test to ensure that the output IC is functioning good on both the channels.
if not go back again to confirm but disconnection of the coupling capacitorr from the pre amp , the power amp , to find the source of the static noise.
it can be self generated from the sound process.
Sep 25, 2010 | GE 46GW 948 46" Rear Projection Television
I recently changed Receivers to a Pioneer. When I attempt to set preset radio channels, the sound sounds like it is coming from the PS 8. There is no treble. Help.
is your speakers broken down and set to the right channels (the presetting of radio channels, should not not affect the sound) is your a-b switch set to one or both? all connections are correct (front/center and rear) . you can also try a equalizer or pre amp that is ready to handle 5.1 system
Aug 24, 2010 | Infinity PS-8 Subwoofer
Pioneer vsx 90txv and bose EQ
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
* I can't find your exact manual so I have to extrapolate features.
I see on the SR>6003< there are Pre Audio OUTS so I'm betting your receiver does, too.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Feb 01, 2009 | Pioneer VSX-90TXV Receiver
I have pioneer receiver Vsx-454 i want to know if this receiver is 5.1 surrounds
Yes. It is 5.1 surround. There are 2 front channels, 1 center channel, and 2 rear channels which comprise the "5" in 5.1 surround. The pre-amp output channel for a sub is the ".5".
Jan 11, 2009 | Pioneer VSX-454 Receiver
I just bought a used Pioneer Elite vsx-49tx receiver on ebay and cannot get any audio output at all.I noticed in the manual that there are 2 u-shaped connectors that are supposed to be in place but are...
You are correct. The Pre-amp outputs must be connected to the AMP-inputs. A dual RCA cable will work just fine. This setup is to allow for easy insertion of an outboard piece of equipment like an EQ.
Dan
Dec 05, 2008 | Pioneer Audio Players & Recorders
Pioneer SX-950
Nov 03, 2008 | Pioneer AVIC-S1 GPS Receiver
35 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
