Question about Dell W2606C 26 in. HD-Ready LCD Television
Tv Doesn't turn on, once I have turned it off.
I have a Dell 26' tv Monitor that once I turn Tv off, it will not turn back on. Tv has to cool down for a while before I can turn it on again, what i usually do is leave it alone when tv is on and goes to power saver, so that it is still on. What is my solution for this type of problem?
    New Friend:
  • 90 Answers
If u do not smell a burnt board, your power bd is ok. u need to replace the main board with the correct firmware update. if u need further ast get back 2 me. i have serviced over 75 of these units, im familiar with them.
Posted on Apr 23, 2009
Lcd tv wont turn on when hot
Either you have to take the TV into a service shop or aim a fan at the back of it to let it stay on longer getting some cool air on it :)
A primary reason for electrical overheating is dust. You might want to get a spray air can and spray out dust where ever dust can get inside the TV.
That's really a temporary fix or something that can prolong usage, but ultimately the TV will need servicing.
Aug 30, 2014 | NEC NLT-26HD1 26 in. HDTV-Ready LCD TV
My monitor will go to black after a while and is
First, try connecting the monitor into another computer to isolate the problem. If it's proven that the monitor is the problem, this monitor needs repair.
I'm not sure if your monitor has a board called inverter. Inverter board is for TV. This is usually the problem once the TV is automatically shutting off after couple of seconds. So, if the monitor has this board, then that could be the problem.
Contact the manufacturer of the monitor for second opinion. But the repair should not cost too much.
Have a great day!
Jan 09, 2010 | Dell E173FP 17" LCD Monitor
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Westinghouse 26" tv SK-26H730S HDMI screen blinks with Dell Comp.
try using the 27 pin monitor input instead the hdmi possibly has a frequency variance
Mar 01, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
Dec 07, 2008 | Syntax LT26HVE 26 in. HD-Ready LCD...
W2600 click but no picture, no warranty
if power light is lit, the main board needs replaced. It needs to have firmware M016, and REV A07. Thats the latest fimware out there available.
Sep 23, 2008 | Dell W2600 26 in. LCD Television
26" TV is inop
repost
Gateway was sued Class action over LCD's and Plasmas they sold over a 2 year period. They resell 3rd party TV's that were very faulty, an immature design.
Here's what I learned about mine, which makes it limp through as a Computer monitor (both DVI and VCA) and halfway functional TV.
You have to connect a DVI source, on the Main Menu for the DVI input there is an option called "Factory Mode". scroll down to it with the CH buttons and select it with the vol button. The scroll to "initialize eprom", select and confirm it. After the "Waitting" words disappear, make sure you have a TV source connected, Then turn the TV off and on, using the hard switch in the back. The TV input should be defaulted to channel 10 or 11 now But you select a TV channel that has no TV signal on it (like channel 1 for example) , the whole TV input side will refuse to let you select it again, and you'll have a blank screen and have to start over.
That takes care of the blank screen thing Now the other problem is parental control is defaulting to "ON" or something, and you can't program channels. With the TV input Main Menu engaged, select "Setup Menu." If you have this problem, then you'll only see 2 options, all the TV input and channel programming options will be missing. You have to select Parental Control, and when it prompts you for a password hit the volume > button 4 times (or just wait for a minute.) This should bring back your TV System and auto prgram/manual search options.
Unfortunately, my TV doesn;t remember these setting very well if I select cable, it does better if I select "AIr". But at least it funtions - kind of. If you switch to your computer input, you probably will have to switch the monitor off and on from the back panel again. Mine always starts up with the menu onscreen. All this might bve less trouble if you have a the remote, I don;t know where mine went after the last move.
Good luck, and hope this helps.
Billy K.
Nov 06, 2007 | Gateway LCD26TV 26 in. Television
Once your turn off the plasma TV, you cannot turn it back on until it cools down
No. If it's a Plasma, you can turn it off and on at will. If it's an LCD, that is true, and Sony's won't let you turn them back on. You would see the power led flashing. Once the LCD bulb cools down then it will turn back on. Hope this helps
Nov 05, 2007 | Pioneer Elite EX500 600Watt A/V Receiver...
Samsung LN-S2641D 26 Inch Wide LCD HDTV w/ Integrated ATSC Tuner Color Issue
if your tv is on warranty take it back to the agent who you buy it from.if it is out of warranty have a tech look at it for repairs.goodluck.
Apr 03, 2007 | Samsung LN-S2641D 26 in. LCD HDTV
Dell W2606C 26 in. HD-Ready LCD Television Logo
108 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
