Question about Kenwood KAC-9102D Car Audio Amplifier
Amp overheating could the the problem be in the ground wire. the reason i say this is because about a minute or two later the amp comes back on.
    President:
  • 3,130 Answers
No, a ground would not make it overheat. Your overdriving the amp, so it goes into thermal shutdown, and when it cools off, it comes back on. You don't have enough ventilation for this amp or theres a idle bias circuit problem. If its a ventilation issue. you could add a small 12 volt muffin fan to the amp. If it's the idle current problem, its going to blow up the outputs device's soon, unless you have this checked out in the shop, under a set of load resistors and a scope.
Posted on Sep 02, 2006
Overheating, loss of coolant, reservoir not working
Sounds like to me your mechanic is on the right track by having the rad cap changed. If the coolant becomes low again in the near future and there is no visible fluid leak on outside of engine or on floor/ground then your problem is internal and possibly a head gasket.
Jun 22, 2012 | 2004 Kia Sedona
My MTX JH600 works intermittently. I don't hear the fans coming on at all and the amp doesn't seem to get hot. Even at low power the amp will turn off all of a sudden and then boom back on after...
One of my friends had a amp like that , i looked at it an the inside of speaker box wires was touching , if thats not it then check ur power an ground , power wire must be the same size ground an if ur ground is not grounded good then u will get the cuting out .
Jun 10, 2011 | MTX JackHammer JH600 Car Audio Amplifier
The Ground wire is hooked up right but the red light wont go off and stay green so the amp will work. It is very frusterating all the cables are the right size its is a 1000 watt amp. I have two 500 watt...
Sounds to me like the amp is going into protection mode. Try placing one sub on the amp with very little gain. One of the biggest reason why this happens is because the subwoofers are wired wrong. What is the brand and model number for your amp?
Apr 14, 2011 | Car Audio & Video
When the oven is turned on about 10 minutes later a f10 code comes on with a beeping. I've tried upluging from the outlet waiting 1 min. before reappling the power cord. I still get a f10 code
The F10 error code indicates a runaway temperature condition. If your oven is overheating, unplug the power cord for a few minutes. When plugged back in if the oven is still overheating, you will need to have the temp sensor & control checked.
Jan 22, 2011 | Frigidaire Gallery GLEFZ384GC Kitchen...
Everything was going ok but couple of minutes later it went red
hi check the ground wire , make sure the ground has a good connection. next, make sure there no wires touching. might wanna check the fuse on the amp,make sure te hass good air flow thanks
Sep 28, 2010 | Sony Car Audio & Video
Marshall MB4410 - Dies and comes back to life every few minutes..
Our bassplayer had the same problem with his mb4410. As it turned out, the fan was not working when the amp got hot. It did turn when cold - go figure! Swap the fan for a good quality (Pabst, Sunon) 80mm pc fan with 2-wire connection. Three or four wire fans will not work w/out modding. See your local pc guy and ask for an unregulated, silent 24/7 fans. He will know. Our bassplayer sold the P.O.S. while still in warranty. HTH.
Apr 26, 2010 | Marshall MB4410 Bass Combo Amplifier
Amp overheats and wont output high volume
It sound like you have a fault on one of the speakers, try disconnecting the speakers and see if still overheats.
Nov 21, 2009 | Car Audio & Video
What u think
Hello jayPRICAN,
You do not say what kind of speakers you are running on the amp and that can affect how you troubleshoot the problem.
Most often, a wiring problem such as a faulty ground or short in the speaker wires will cause such a problem. Here are the most likely causes for the amp to go into protection.
1) When a speaker wire is shorted or grounded.
2) Overheated.
3) When a ground wire of the receiver/head unit or the amp itself is not properly grounded.
4) When the amp itself malfunctions and a DC is sent to the speaker output.
First check your power, ground and remote turn-on wires. Then disconnect the inputs and speaker wires. If the amp does not power up normally with all the other wires disconnected, the amp itself is defective. If it does power up with everything else disconnected, reconnect the wires one at a time to determine where the problem is located.
Hope this helps.
Aug 31, 2009 | Kenwood KAC-6104D D Class Mono Power...
No sound
I would try it without the slot for the additional amp. However, there is a chance that it is fried. When its powering up I would check the voltages with a multimeter to make sure everything there is in order.
Jul 02, 2006 | Infinity 7540A Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
51 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
