Question about Tunturi T30 Programmable Treadmill
TUNTURI T30 Errorcode E1
My Tunturi treadmill doesn´t work. When I switch it on, it takes about 10 seconds before E1 appears in the display. The board does´t run at all. The speed sensor is checked, and it works properly. It looks to me like the motor is not getting power. I can´t read more than 10-12VDC when the mill is running at top speed. Every button appears to be working, and no obviously faults can be found... Can anybody help me?
SOURCE: Abrupt stop Tunturi J 660.
I am all set. I located a Tunturi service person in my area. We have an appointment set up. Thanks for following up. I. Hazelhoff
Posted on Jan 22, 2010
maxtreadmill
  • 832 Answers
SOURCE: Looking to buy a good quality treadmill for home.
Tunturi unit have been always a reliable unit and they do not have very many problems. I like and sell the Sports Art products for five years and they are reliable and sturdy units, at one time they were manufacturing for Tunturi and other highly visible companies in their 30 plus years in the industry.The only worry is, do you have a reliable service company that will take care of you if whatever product you choose to purchase. I know as a servicer I rely on my vendors to give me great service so I intern give great service to my customers.
Posted on May 15, 2010
  • 15 Answers
SOURCE: Where can I purchase a teflon spray lubricant for treadmill?
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
Posted on May 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: My Tunturi Treadmill ramp is stuck in the top
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Posted on Jun 14, 2010
SOURCE: tunturi j 661 f treadmill won't start.says E1.
Treadmill wont start-up
Posted on Jul 20, 2011
Have a J620P and just received a 51 code. What is it, and how do you fix it?
Follow the next step:
Scan by 3 seconds for to clear the error the display and restart the treadmill
If the error Do not appear,continue.Electrical fluctuation can be have actuated in the system electric power, and cause the display error.
If the problem persist call:206-881-7392 tunturi treadmill
God bless you
Oct 01, 2013 | Tunturi Exercise & Fitness
Can we use 180 vdc motor in replacenet to 260 vdc motor on our tunturi t85 thread mill?
We can sell new motors, power boards and other spare parts for Tunturi T85 ain.vari@gmail.com
Jun 28, 2012 | Tunturi T85 Treadmill
I have a Tunturi j770 treadmill with error code E1. What does this mean please?
Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
May 17, 2010 | Exercise & Fitness
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
Looking to buy a good quality treadmill for home. Is the Tunturi T30 worth considering? I will mainly be power walking. The Lifefitness are very expensive...any other brands you recommend? I i live in...
May 10, 2010 | Tunturi T30 Treadmill
E1 code
Your problem might be that a magnet has fallen off within the treadmill. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Apr 28, 2010 | Tunturi T30 Programmable Treadmill
Crank Bearings
Call Accel Fitness of North America they the distributors of Tunturi Fitness. call them @ 1-888-388-6887
Mar 13, 2010 | Tunturi T30 Programmable Treadmill
How do i change the belt on a tunturi 440
Sorry. no easy way, you have to take it apart. Be careful you don't break the plastic tabs on the corner covers or they will never go back together properly.
Sep 21, 2009 | Tunturi T30 Treadmill
Tunturi j440 the console is not lit up when switched on and nothing is happening,checked the plug etc.
try turning the switch off then on while plugged in to reset the electronics.
Jul 16, 2009 | Tunturi T30 Treadmill
Tunturi T30 Programmable Treadmill Logo
82 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
