Question about Canon i860 InkJet Photo Printer
How do you clean the print head?
My printer won't print. I have removed the color cartridges several times and replaced them. That didn't work. I checked the paper feeder and everything appears fine. I have currently removed the cartridges and print head. How do I clean it? The amber light blinks 5 times
  • Canon Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Feb 25, 2012
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: one colour won't print. tried new cartridge but
Posted on Aug 12, 2011
Color won't print - Deskjet F4210
you are having a defective printer head so just got it replace or get another printer
Feb 04, 2013 | HP Deskjet F4210 All-In-One InkJet Printer
I'm trying to get my Canon iP4200 to print in BLACK ONLY
Hi . I think the print head may be is clogged. If cleaning didn't correct the problem . Print head need to be replaced
Jun 25, 2017 | Canon PIXMA iP4200 InkJet Photo Printer
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
Can I remove & clean the print head on an Epson printer?
i've tried to remove it from the sliders and to have it soaked in alcohol for about 10 hours without any luck. It is too much work without any guarantee. I suggest to junk it and get a new one (if possible with heads on the cartridges so they are replaced with each refill)
Mar 09, 2012 | Office Equipment & Supplies
Printer won't print black color
hi Kelly,
  • Make sure the cartridges is well latched into their slot and also well vented by:-
  • Turn the printer on.
  • Access the cartridges by opening the ink cartridge door[lift the upper case of the printer].The carriage will move to the center so you can see the cartridges.Wait till its silent.
  • Remove the cartridges from their slots by pressing the tabs in front of them.
  • Most of the cartridges are usually with an orange tab fixed just above the hp logo.Make sure its completely removed to vent the cartridge.
  • Re-install the cartridges making sure they go into the right slots.Note that each cartridge goes into their corresponding color slots.
  • Also you can clean the print head by:
  • Load a plain A4 size paper.
  • Go to printers control panel and select setup.
  • press > arrow and then select tools and ok.
  • Press the > arrow again and then select 'clean printhead' and OK.
  • The print head cleaning will begin.
  • Now try printing after head cleaning ends.
Hope this helps.Thanks!
Oct 06, 2011 | HP Officejet 6500 Wireless All-in-One...
I have hplaserjet pc1515n color printer but when iam giving it print it give black and white not in color.
I have a similar HP Color Printer on my desk. I think that your printer is set to PRINT IN GRAY SCALE
- Go to Control Panel
- Open 'Printer & Faxes'
- Right Click the Printer and choose 'Printing Preferences
- Go to Color and un-check 'Print in Gray scale as shown below: -
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 30, 2011 | HP LaserJet CP1515n Printer
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
My Lc61 will not print black--on the test page, the colors are fine. I've replaced the ink cartridge and it says it's full but won't print
Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
May 26, 2011 | Brother Office Equipment & Supplies
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
109 people viewed this question
old marine
old marine
