Question about Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker
Bread machine need pan for Zojirushi model BBCCs15 and also the black plastic base that the pan sets on is broken on one side. Can it be fixed?
  • 368 Answers
Hi spudguard,
If you're looking for OEM parts, I'd go to
http://tinyurl.com/3jmx4g
There's a Service & Support link at the top of the page - locations of service centers and the like.
You can also call Zojirushi Customer Service Department - -
800-733-6270, M-F, 8:00 a.m. to 5:00 p.m. PST.
Also here's a TinyURL for the manual download page, just so you have it.
http://tinyurl.com/z39gu
If these don't pan-out (no pun intended, I think), the next place I'd start hunting is eBay.
As for fixing the black plastic base, you'd have to describe what kind of plastic it is, and whether or not you plan to DIY or have it done, is it subject to high temps, etc. For a lot of that stuff, it's easier to get new unless you're going to glue it up yourself, but you should know what you're doing or get help. I'll give you more advice if you give me more information.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 04, 2009
Rubber gaskets on the zojirushi bread mach. wore out need to replace
Your bread pan has no user-servicable parts. Please contact Zojirushi for a replacement bread pan assembly. www.zojirushi.com
Jun 19, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
Do u have and old style bread macine and I lost the insert that mixed the bread, Number on the back 0131026. How can I get one?
URL for Zojirushi
WWW.Zojirushi.com
support tab
FAQ
Spare Parts
Bread makers
Find your model on list
pan is $70.00 +$11.00 Shipping
Manual download at support tab
Feb 11, 2011 | Zojirushi 330700 Bread Maker
No matter the recipe I choose, the bread resulting from meticulous attention to ingredients is always very dry duing the kneading process, mealy and dense once cooking is complete. When I first got my...
Hi, If you are doing everything as before and not getting the desired results then it could be that the belts are slipping and not allowing the paddles to fully incorporate all the ingredients. Either that or the paddles themselves are sticking and not moving freely. The belt problem is an easy fix but if the paddles are sticking then it could be the sealed bearings the paddles rotate in is failing and a new bread pan is needed. To check this, take the empty pan and paddles out of the machine and see if you can turn the paddles freely by hand. if no then the sealed bearings are failing. If they turn okay then it could be the belts. Belts and motor are located in the base of the machine. Unplug machine before checking them. Also, make sure the pan is seated correctly in the machine. Hankl
Nov 05, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Paddle shaft unable to rotate in the breadpan.
Hi, There is a sealed bearing in the base of the bread pan. When this sealed bearing fails the paddle gets stuck and will not turn. Take the pan out of the machine and see if you can turn the paddle by hand. If it doesn't turn freely, then it's probably the sealed bearing that is is failing. If it turns freely, then this is good news. Keep the pan out of the machine and go to a kneading cycle. Look through the lid window to see if the motor shaft is turning. If it is not turning, then a belt fell off , needs to be tightened, or has broken. Motor, belts and pulleys are in the base of the machine. Remember to unplug machine before working inside the machine. Finally, make sure the pan is seated in the machine correctly. Good luck Hankl
May 11, 2010 | Black & Decker Bread Machine
I have a Zojirushi bbcc-s15, and it started to leak from the bottom pan. The felt washer on the bottom has fallen off. Where can I find or how can I replace the outer and inner parts?
All those parts are part of the sealed bearing that is stamped into the bottom of the pan. Unfortunately they can't be replaced and you will need a new bread pan. Sorry Hank
Mar 10, 2010 | Zojirushi BB-HAC10 Bread Maker
Replacement part for my Zojirushi BBCC-X20 Bread Machine
That sub component consists of a sealed bearing and seals that are spot welded onto the bottom of the pan. Unfortunately you can not purchase this assembly separately. Sorry Hank
Feb 12, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Bread Machine non-stick starting to peel off
Since your machine is only about 6 months old, it should still be covered under warranty. I'd contact the manufacturer. (Contact information should be in the instruction manual). The teflon coating is just a sprayed on coating. Once it starts to peel, it's not safe to use them. It becomes hazardous (possibly eating it in the bread).
It sounds like you've taken care of the pan as it's supposed to be. If this was an older machine, I'd suggest ordering a new pan. You can find them on the internet quite easily.
Apr 01, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
Broken - one of the 2 black tips that rotate the bread container
OK not easy but I took out the coupler which had the tabs broken off and drilled with a drill press two holes which I then threaded for two small brass bolts which I cut to mimic the broken prongs. I couldn't find the coupler anywhere and didn't want to toss a good machine. This is a hassel but kept me with a project and out of trouble for about an hour :)
Nov 22, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker Logo
62 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
