Meaning of xp,sp,lp,ep in recordind
LG DVD RECORDER DR 175
2 Suggested Answers
  • 2318 Answers
SOURCE: codes
Those terms mean the speed that the VCR can record programs.
SP Standart Play >>> 120 minutes.
LP Long Play >>>>>> 240 minutes.
SLP Slow Long Play > 480 minutes.
Posted on May 06, 2008
I recorded video from my Sony Handycam to the RH387H HDD and then wrote the video onto a DVD-R disc using the XP setting (instead of SP, LP.....). The disc can only playback now on the LG387H, but cannot...
make sure the disk is finalised after recording, if this does not help then the bit-rate it uses for xp may not be compatable with other dvd players, in which case stick to sp,lp or dual-layer sp is best if ou can.
Jan 25, 2011 | LG RH1999H DVD Recorder/HDD Recorder
VCR LP/EP compatibility
Vdumitre -
No, not usually. If you've recorded a tape at LP and put it another machine that doesn't have LP, it usually won't play properly. Some machines that have only SP/EP will do this, but they are got scarce as more manufacturers dropped the LP speed. Your best bet is to buy an older one from a thrift shop or a garage sale, making sure that it will play LP. Then, copy your older LP tapes to SP or EP (Run the OUT from the LP unit to the IN on the SP/EP unit, and choose "record from line in", "aux", or "rear input").
Thanks,
videoman7
Aug 05, 2009 | Sony Televison & Video
Recording from VHS to DVD
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
JVC DVD Recorder – Finalizing and disc space
-Tha Mp3 Doctor
My JVC DR-MV7 will play most DVDs and even record, but recently, it stopped being able to finalize. After I get the message saying "finalization has failed," I can't even play the DVD anymore - thus losing...
My JVC DR-MV7 will not accept any disc for playback. I insert a movie disc and it consistently rejects them. After about 15 to 20 attempts, sometimes it will stay and begin reading the disc. It also sounds like some internal components are encountering some resistance (moving parts inside?). Any ideas?
Nov 27, 2008 | JVC DR-MV7 DVD Recorder/VCR
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Codes
May 06, 2008 | Funai FDRV90E DVD Recorder/VCR
DVD recorder fault
This is correct. I suspect you can also see "SP" lit up next to it. You should also see "XP" above it (dimmed) and "LP", "EP" below it (also dimmed). Standard Play (SP) fits 2 hours on a single layer disk. XP only records 1 hour but at a higher quality. LP gives you 4 hours and depending on the setting EP will give you 6 or 8 hours on the same disk. The manual will tell you how to select the quality setting
Dec 13, 2007 | Panasonic DMR-ES10 DVD Recorder
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
