DIM LCD - Computers & Internet
  • 749 Answers
1. Use the menu on the monitor to turn up the volume
2. right click anywhere on the desktop- select properties - select the "settings tab" at the top - click on the "advanced" button. this will open your video cards display settings .
you will need to look for a brightness controll or color corection section to adjust the brightness as all video cards have different software for controll.
Gamma will increase you brightness also. a ballance od gamma and brightness is neccessary, so change em both small amounts , then check your desktop or applications, then re-adjust.
This should Fixya up ! Please rate.....
Posted on Oct 28, 2008
I got samsung laptop R580, the screen broke because of falling so i ordered online, and replaced it with new one myself, it was working fine for two weeks but after two weeks the screen went very dim! I...
The inverter could be faulty. The inverter supplies high voltage to the CCFL lamp that provides the back light. The inverter is located at the bottom of the LCD screen between the hinges.
Sep 09, 2012 | Computers & Internet
Aspire One screen has gone dim.
Inverter is inside the LCD Screen. Mostly at the bottom in the middle. To locate the Invertor, you have to take apart the LCD Screen by removing the LCD Frame, removing rubber pads & screws (depending upon the Model of notebook you have). Moreover, the cause of dim/ dark display could be the faulty lamp. So, I recommend that you check both the Inverter and Lamp.
Another likely cause is a bad connection of power from motherboard to the LCD. So first check the connectors/ wires for any damage before proceeding to replace Inverter of lamp.
For your convenience and idea about LCD Display, I have found a general link about CCFL replacement. Click here for detailed and graphical DIY instructions about LCD disassembly.
Make sure you take proper precaution while working inside LCD, as the inverter generates a very high voltage.
Hope it helps! Good Luck! Thanks for using Fixya!
Oct 19, 2011 | Acer Aspire One PC Notebook
Lcd screen is dim and blinking
Hi lcd dim and blinking usually points to your backlight inverters. They are the boards that turn on the light on the back of your lcd scren so that you can see the picture.
You can get parts at
Sep 30, 2011 | Sony KDL-46XBR4 46 in. LCD Television
My screen is very dim
boot to the BIOS (F2 at boot) and ensure that the LCD brightness is set to 8 and then reboot, if LCD is still dim, then, check the Control point system manager display settings and see if the LCD is dimmed there.
If no change, run diags Power + D at boot to run the LCD BIST test , if the 4 colored screens are DIM during the test, then the LCD has failed and needs repplacement.
Jun 29, 2011 | Dell Latitude E6500 Laptop
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
Sep 23, 2009 | Dell Latitude D505 Notebook
Dim screen
Your LCD has a small problem its cold soldering. Its a factory depict try to fix its on electronic shop...
Aug 08, 2009 | Dell Computers & Internet
Satellite L45-S7409, Screen is very dim.
Try reseating the lcd cable on the back of the LCD and also where it plugs into the motherboard. If you still can't get a normal screen and it stays dim then its going to be either your lcd is bad or the inverter that supplies the voltage to the lcd (inverter is located underneath the lcd, small rectangular board) is bad.
Aug 08, 2009 | Toshiba Computers & Internet
Toshiba equium A100-306
try function key for lcd it may be in presetaiton mode by mistake
or is lcd on / come on bright then go dim / dark just very dim if so your backlight is out replace lcd
Oct 24, 2008 | Toshiba Equium 7100S PC Desktop
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
