Question about Pelco Home Security
Pelc0 model ics-150a wire sceme
Wire diagram
Which is the diagram or service manual of my soundbox BAM 150a because I am trying to find it and can not ?
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Search the site by type in the "IC Number used at the power regulator" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 06, 2016 | Televison & Video
Wiring diagram for Cocao-Sox Covert Spy Hidden Hat Camera.There are three wires that are attached on the large PC board with a Large IC and next to it there is a smaller IC there is also a heat sink...
Since you have meter, check for this:
Red is mostly used for supply voltage; likely 5VDC.
Black is mostly ground.
Blue is often used for a switched supply line.
Good luck-
Dec 25, 2014 | Televison & Video
Wiring diagram for Tote-A-Volt Model 150A
Red to bat+ of starter relay
Blk to bat+ (red) of alt
Blu to field (hacked into wiring)
Grn to ground
Wht-1 to stator (blk) of alt
Wht-2 to stator (also hacked into wiring)
Oct 14, 2014 | Cars & Trucks
Need wiring code for amx 150a mic
Check this link to find info about mic wiring codes for different brands.
Nov 29, 2010 | Uniden Radio Communications
Im trying to wire my radio to my car, but the colors on the inside of my car are different to the ones Im acustomed to...plz help
No mater what color sceme you have the wires all play the same roll. Ground/ power/ common. B/W , Red, Yellow, purple/wh, brown , some cases blue, blue /wh and green. Check all wires for power on and off circuit with test light. black to ground - side speaker rd to + side etc;
Mar 04, 2010 | Car Audio & Video
Can someone provide a wiring diagram for the
hello, my name is paul and wondering if you can help me with a wiring diagram of cool talk throat mic icom earpiece, hope to hear from you soon .
kind regards
paul
Dec 05, 2009 | ICOM Informatique IC-A23 VHF NAV/COM Air...
Home Security Logo
Top Pelco Home Security Experts
Lawrence Oravetz
Are you a Pelco Home Security Expert? Answer questions, earn points and help others
