Question about Philips 32PW8608 32" TV
Phillips 30" Mod 30pw633r37a
I have a 30" philips widescreen Tv. It started making a high squeeling sound occasionally and the picture gets wiggly. Now it is doing it all the time. The tv is 18 months old and no longer under warranty.
  • 1 more comment
  • Loudlarry Dec 30, 2007
    Started squealing and would stop if you changed channels now it just keeps doing it and the sides of the picture are all wiggly.
    had the surround sound dvd system and it took a dump a year ago just after warrenty ended, I'll never buy this crap again
  • tresa1 Apr 01, 2008
    I have the same problem high squell and wiggly picture.I have changed my connecters and moved television diffrent areas of house . I will never own a phillips tv again
  • sneakytoes Dec 22, 2008
    Mine would do this for a day or two, then stop. It's been months since it happened, until today. I turned it off and now it won't turn back on.
I unplugged it for 24 hours. When I plugged it back in it was ok. It has done it a couple of times since, but only for a few seconds.
Posted on May 14, 2007
I have a Samsung HL-P5067W/HL DLP tv. When I turn it on cold the lamp light blinks on and off. The fan makes a high pitch sound a relay clicks the TV goes back to standby and the lamp light starts blinking...
This sounds like a lazy lamp--that is getting hard to start. Try a new lamp first. If you are inclined to do so--get a bard bulb and install in the old lamp housing and save some money. Get a real PHILLIPS bulb--it will last a while--compared to cheap generics that are good for maybe 6 months !!
Feb 18, 2014 | Samsung HLP5067W Television
Phillips tv stand by button stuck no sound r pic mod.no.42pfl9632d/10
the model is phillips and picture above is Hitachi--the philips is not customer repairable--call around and get a estimate.
Oct 17, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television no Picture no sound
Are you getting some kind of high pitched squeel from set when you try to turn it on?
The more you tell me the more I can help.
Nov 10, 2011 | Philips 60PP9202 60" Rear Projection...
My phillips 19pfl3504df7 suddenly went from widescreen to a small screen how do i change it back
Look for a button on your Philips remote labeled Format. This button will cycle through the picture formats available for that signal. Press it until you find one you like.
Hope that helps!
Jul 19, 2011 | Philips 19PFL3504DF7 19 in. TV
Phillips tv picture folds down from the top, as if
It sounds like a defective capacitor in the deflection circuit. Check all of the high voltage caps.
Aug 09, 2009 | Philips Televison & Video
About a month ago my Phillips 55" widescreen projection TV started to have picture problems. On the left side of the picture it looked like the colors were spinning, then after a while the picture just...
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Jul 18, 2009 | Philips 55PW9363 55" Rear Projection...
Philips 30PW633R37A pops, then no pic, no sound.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 21, 2017 | Philips Televison & Video
Phillips 30PW633R37A - Wont Turn on.
Hi Panix:
Sorry, but it sounds as if the power supply or high voltage circuit has failed. You will have to take it to a repair shop.
Feb 24, 2008 | Philips 32PT6441/37 32" TV
Philips 32PW8608 32" TV Logo
424 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
