Question about Dryers
Runs but wont heat - Dryers
  • 4 Answers
There are 3 thing you can check. The heating element, thermostat and thermal fuse. All 3 should be together. Depending on you dryer u can access then by removing the back panel or the front. You can use a multi meter on the continuity option to test. You should have continuity in each.
Posted on Feb 24, 2012
Distuber advanced all the way at num 1 wont start
hi. engines do run bad when they are over heating. you first need to correct the over heating. then if there nothing else wrong it should
start and run ok.. good luck
Feb 18, 2014 | Toyota Corolla Cars & Trucks
My dryer wont heat
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
May 06, 2012 | Whirlpool Dryers
My dryer wont heat up or shut down
It's not heating up because the heating element is broken and should be replaced. It won't shut down because the thermostat isn't sensing heat and continues to run while expecting heat. So replacing the heating element should get it running properly.
Mar 23, 2010 | Whirlpool LER5636P Electric Dryer
Heater wont run on hi and doesn't get warm at all
One of two things here. You blew an internal fuse or the heating element is broken. Take your unit apart and check for bad fuses and also check that the heating coil has continuity. Let me know how you make out.
hardrocko
Feb 07, 2010 | Holmes Products HFH5606-U Compact Heater
Dryer wont heat
could be the heating element cant check with meter have to open her up and see if one of the heat coils is bad a new one will cost around 80$
Jan 14, 2010 | Kenmore 73952 Gas Dryer
My dryer wont heat, but air flows well. Also, it
# 1 Check to see if your timer is turning as the dryer is running. If not it will need to be replaced.
# 2 You will need to verify that your heating element is coming on when the dryer is running
Oct 02, 2009 | Dryers
Water wont heat up
If your DW has an "energy saver" or "no-heat" button for wash or rinse, make sure it is not selected.  If that is not the case then the heating element is probably burned out and needs to be replaced.
Jun 02, 2009 | Beko 24 in. D3421F Free-standing...
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Dec 19, 2008 | Whirlpool LGR5634L Gas Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
