Question about Sharp 13L-M100 13" TV
Sharp Model# 25j-m180 Television
Television started showing rainy with the picture in the background showing faint...
What is wrong?
Again you can see what every television program your watching, but its faint in the background behind all the rainy greyish distortion.
if you can e-mail me the solution also just in case to
  • 1074 Answers
SOURCE: tv will not cut on
there is no recall on sharp tv that i know about if your tv is still on warranty take it back to the supplier.if the warranty is finish call a tech the tv has a problem in the power supply and related circuit.good luck.
Posted on Apr 14, 2007
  • 1139 Answers
SOURCE: Sharp television model 32c241
This is a power supply problem. It may be as simple as a blown fuse or as complex as a problem with overvoltage and overcurrent events within the circuitry of the Horizontal and Hig Voltage sections of the set. If it is a fuse that's simple to replace, the other well that can get kind of involved. In any event I would suggest that you get the set analyzed by a qualified Television repair person.
Posted on Sep 22, 2007
  • 252 Answers
SOURCE: Sharp 36 inch television-PAL to NTSC conversion
to convert your tv from pal to ntsc ,find the ceramic filter value 5.0 , 5.5 or 6.0 and change it with 4.5 and . Take note that the ceramic filter of sound and video are defferent ever if it is the same value
Posted on Oct 08, 2008
SOURCE: Sanyo DS35590 35" CRT Television
i have the 35 inch TV model ds35590 and the chasis number is 35590-00. what TV is doing is when you plug it in even before you turn the power on it will blow the fuse i have checked all the rectfires. i havd checked the Horzontle transistor also. not sure about the regulator dose any one have any idea what would cause that on this tv it is a sano and i know from past exparance most TVs have little querks that causes problems. Thank you
David If you do have any ideas could you e-mail mme at
Posted on Oct 11, 2008
SOURCE: Can't turn off SAP/MTS without remote
Dynatron MR 110 available at various sites including Amazon.
Posted on Jan 11, 2010
Turning off
Hi dcough2,
haev you tried to unplug it for some minutes, and then connecting it back again?
Anothwr thing to revise is if the socket is used for more than devices than the TV, it could also be weak power, so your TV image fait, or go dark, or it just shuts off because it have not enough power to use.
Jan 01, 2008 | Sharp Aquos LC-32D40U Television
Sharp instruction manuals
Contact Sharp customer service on the web..Sharp website...give them the model number you gave us.
Sep 04, 2014 | Sharp 25J-M100 TV
For about 6 months there has been a faint gray/black verticle line running down the middle of the screen . is worse on blue/green backgrounds, and is almost not noticable on white backgrounds. I know that...
I've seen a similar looking problem and it is a bad LCD panel. It will show even on a non-used input, and will show through the menu screen and the screen saver, also. Sharp's LCD panels are very expensive,too. Over 4000 at encompassparts.
May 03, 2010 | Sharp AQUOS LC-45D40U 45 in. LCD...
Does my sharp tv model 25k-m180 have a digital tuner
No,all regular tube tvs are analog tv.Must have a converter box hook up to get a free over the air DTV,or must have pay tv services like Cables,Satalite,or Telicoms signals they convert DTV back to analog signal for ur tube tv.
Apr 27, 2010 | Sharp 25K-M180 25" TV
Input jacks in Sharp 25J-M100/ Pc to Tv cable
You can purchase an s-video to composite video connector to view your Dell computer's television output on your sharp CRT television, though the image will be a bit blurry because of the connection and CRT technology limitations, though streaming video probably can be seen just fine. An example of an s-video to composite video connector can be found here:
but you probably can find a cheaper priced unit somewhere else, maybe even at radioshack.
I hope this helps!
May 18, 2009 | Sharp 25J-M100 TV
Code for universal remote
One website (Universal-Remote.Net) , says the setup code for a Sharp TV, using a Philips universal remote, is one of the following numbers: 002, 013, 014, 111, 502, 712, 812, 813, 913, 918.
Hope these numbers work for you. Please take a moment to rate this info, using the rating system below, after you have tried these numbers. Thanks.
Jul 15, 2008 | Sharp 25J-M100 TV
51F59A model hitachi rear projection tv
You may need to set your screens look at the picture when you have a real dark background if there is faint lines in the picture then the screens should be set correctly
Jun 11, 2008 | Hitachi 50V715 50" Rear Projection...
SHARP TV - MODEL 25j m100
The RF jack is solder directly into the tuner module and as long as it did not break the circuit board inside that it connects to, it can be repaired . Takes a lot of heat though to solder the jack to the frame of the tuner. Sometimes I use 2 irons to get it hot before the plastic guts of the jack melt too bad. Also is sometimes hard to cram the jack back into its mounting hole, may need to file it out some. The makers don't solder these on they are just pressed in and crimped which is why they break off so easily. I recommend using the push on type cables to avoid this problem. Don't forget to solder the center conductor into the tuner board.
Hope Ya Fix It!
Feb 21, 2008 | Sharp 25J-M100 TV
Sharp 13L-M100 13" TV Logo
65 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
