Question about Rohl R77V3SPN Country Pull-Out Bar Faucet with Short Handspray - Polished N...
How to remove the filter screen on Rohl R77V3SPN Country Pull-Out Faucet.
Rohl R77V3SPN Country Pull-Out Faucet. How to remove the filter screen for cleaning.
SOURCE: Problem taking the top cover off the Rohl R77V3SPN one handle faucet
With a small flat blade screwdriver, carefully remove the red and white plastic button on the front of the faucet. Turn off the water supply. Then, raise the handle like you're turning on the water and move the handle slowly left and right until you can see an Allen screw through the hole where the button was. With the correct size Allen driver, remove the screw and the handle will come off the faucet.
Posted on Aug 29, 2009
  • 126 Answers
SOURCE: Rohl R3830 pull out faucet: loss of water pressure
try where the hose connects to the pull out spray,s/b a screen there
Posted on Jan 08, 2011
packrat1948
  • 528 Answers
SOURCE: how do you remove the
It just unscrews counter clockwise.
Posted on Feb 07, 2011
packrat1948
  • 528 Answers
SOURCE: The spigot on my my bar sink Rohl Country Kitchen
That is an internal failure of the faucet and you will need to contact Rohl for a possible warranty replacement.
Posted on Mar 05, 2011
jyackle5
  • 8197 Answers
SOURCE: How do I remove the
To learn how to remove the handel You will need to call at 800-777-9762. Sorry we do not have the breakdown diagram for you. They will walk you through how to remove.
Posted on Mar 16, 2011
I have a rohl model r77v3 faucet. is it supposed to rotate on o ring on top of counter? or on the base ring?
All the info is here. Trim Ring, O-ring, Counter.
[PDF]R77V3 (Metal Lever) R77V3LP (Porcelain Lever) - Rohl www.rohlhome.com/pdf/R77V3.pdf
  1. Cached
  2. Similar
R77V3 (Metal Lever). R77V3LP (Porcelain Lever) www.rohlhome.com. Consult your local ROHL showroom for additional information and specifications.
[PDF]ROH8734 Maint Bro_f.qxd - Rohl
https://www.rohlhome.com/pdf/489.pdf
  1. Cached
R77V3 (Metal Lever) www.rohlhome.com ... For complete warranty details and a list of showrooms, go to www.rohlhome.com. ... NOTE: MODELS MAY VARY ...
Rohl R77V3 Single Lever Pull-Out Kitchen Faucet with Metal Lever ...
https://www.ajmadison.com > Sinks & Faucets > Faucets > Pull-Out
  1. Cached
Rating: 3 - ‎3 reviews Brand: Rohl. Series: Country Collection. Model: R77V3. Dimensions. Faucet Height: 8 1/2 Inch. Faucet Reach: 9 Inch. Base Width: 2 3/8 Inch. Cutout Size: 1 3/8 ...
rohl model r77v3 Google Search
Dec 02, 2016 | Rohl Plumbing
Would it be cartridge or something else
Not the cartridge. There are O Rings around the spout that wear out. These need replacing. Call Rohl for replacement parts
www.rohlhome.com/warranty.aspx
Jul 07, 2014 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
How do I replace the hose on a rohl 3810 faucet pullout pray head faucet
contact ROHL customer Service, request a new hose (part number R45158), detach the end on the underside with a wrench and pull it out. Insert new hose through the topside guide neck and reconnect on the bottom connection.
Nov 02, 2013 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Guide to Replacing Cartridge on Rohl R77V3
Look carefully at all the prongs and receiving slots in the body of the faucet into which the cartridge goes to insure proper match.
Mar 03, 2012 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
I have a Rohl R77V3STN Pull Out Faucet, and the handle to turn on the water is becoming increasingly stiffer as I turn on the water. I see a post that says to clean and grease the seals every 2-3 years....
Call customer service right away. 1 800 777 9762
Mine is now stuck, and she said if I had called when it was still moving, they could send a free part. The only other option would be that they send a refurb faucet for a $50 charge. I said no thanks, I'm not paying another cent for this faucet--there's a lifetime warranty! The warranty states replacement of product or parts free of charge.
I'll try the part. as the faucet will move if I force it. (I used a little wd40).
Apparently mine was made in New Zealand, where the water doesn't have as much chlorine.
If the part doesn't work, I'm calling them back and raising the roof!!
Sep 26, 2010 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Single lever with pull out accessory sprayer. Too little flow from the main spout. The pull out sprayer has more pressure than the main spout. I suspect the diverter valve is the trouble. What is the...
The Diverters Parts is C7005. Here's the parts breakdown for your Rohl faucet. Contact Rohl and have them send you new diveter for free, the A3608 seriers came with a limited liftime warranty.
Sep 17, 2010 | Rohl A3608/11LMAPC Single Lever Country...
I'm going tobe replacing the cartridge in my Rohl
It is highly suggested to use the grease. The purpose of the grease is for (break-in Period). Without the grease, gaskets and seals rub dry and hard against the metal surfaces and could distort or wear uneven and fail prematurely. The grease helps ease the initial wear and give a better life. Also, it isrecommended toopen a faucet and clean and grease seals and gaskets before they are bad;sort of a preventive maintainance every 2 to 3 years. Good luck, Macgivor
Jan 16, 2010 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Mar 26, 2009 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Nov 06, 2008 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Rohl R77V3SPN Country Pull-Out Bar Faucet with Short Handspray - Polished N... Logo
53 people viewed this question
Top Rohl Plumbing Experts
Donni Steen
obsteiner
john h
Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
