Question about Coffee Makers & Espresso Machines
Jura f50 does not rinse
My Jura F50 does not rinse out the coffee spout and when making coffee the water blows by and goes into the drip tray at the back. he grounds eject dry.
4 Suggested Answers
  • 14 Answers
SOURCE: Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to www.hotncold.com Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
Posted on Aug 03, 2008
  • 13 Answers
SOURCE: Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
Posted on Jul 08, 2009
  • 3 Answers
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Posted on Feb 19, 2010
Jura f50 repairing
Probably just needs to be cleaned inside.
This is good video for most models. Parts Guru can do it for you if you don't think you're up to it. Or rebuild the brew group for you.
https://www.youtube.com/watch?v=mZwkqPeZ0QY
Jul 29, 2014 | Jura Impressa F50 Classic Automatic Coffee...
I have the Jura Impressa F50, the machine will no longer function when the coffee grounds conatiner is in place. I have reset the machine several times, have put the container inr\ different positions and...
on the tip of the tray there are metal contacts that tell the machine that the tray is installed. try cleaning these contacts with steel wool and on the inside of the tray with soapy water and a brush. remove excess water from tray and try
Apr 14, 2014 | Jura Impressa F50 Classic Automatic Coffee...
Feb 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
Both spouts seem clogged
I have a Jura Impressa F7 that had the exact same issue. To solve it was pretty simple. Try and make a cup of coffee, and while the machine is trying to pump the coffee thru the spouts, grab the chrome handle on the spout and vigerously move it up and down rapidly. You should notice small grounds of coffee dislodge and follow the stream of coffee into your cup. If you do this a couple of times, you will be able to clear the trapped grounds within the spout. Hope it works for you as well as it worked for me.
Jun 23, 2009 | Jura Capresso Impressa F9 Espresso Machine
Mike
Feb 05, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
