Question about Maxtor One Touch II (EO1E200) 200 GB Hard Drive
Hard drive won't read
  • 1 more comment
  • David Stickney Feb 24, 2012
    My Maxtor external hard drive worked fine yesterday. Today my computer keeps saying that I have to reformat because it cannot read the drive. What can I do to avoid losing everything on the drive? Is it even able to be fixed?
  • David Stickney Feb 27, 2012
    There is no tool option when I right click the drive. It shows up on disk management, but only gives me a few tabs in properties.
  • Brian Sullivan
    Brian Sullivan Feb 27, 2012
    only half answered the problem
    if you cant access the drive you cant format it
    make sure the lead/s that attach to your hard drive are securely seated
    if your computer came with a motherboard disc the drivers could be on it
    click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
    right click to reinstall drivers or
    if you can see your usb but its not working
    ports(com&lpt)right click update driver
    hope this helps
    sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
    just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
    check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
    if this fails to fix the problem
    you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
  • Maxtor Master
  • 27,725 Answers
Can you see the drive ? if yes
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
Posted on Feb 25, 2012
My book hard drive won't read
1. First try to use another usb cable. If it still won't work.
2. Try plugging it into another computer. If it still won't work.
3. Try removing the hard drive from your BOOK HARD DRIVE, and plugging it directly to your computers desktop SATA socket using a SATA cable. If it works, backup all the data of your BOOK HARD DRIVE and then delete the partition and make a new partition and then format it.
Jan 25, 2013 | Computers & Internet
My CD drive won't read anything?
you need a new laser by the sounds of it
Aug 01, 2012 | HP Computers & Internet
Sylvania SDVD6660 usb won't read portable hard drive
your hard drive must be formatted for FAT32 and NOT NTFS.
May 08, 2012 | Televison & Video
Why won't my dell laptop cannot read the primary internal harddrive?
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 08, 2012 | Dell Inspiron 1545 i15-143P Jet Black PC...
My cpu won't recognize my LACIE Minimus Drive. I have no Setup Assistant and I need the info locked on the drive. What do I do?
Go download EASEUS Partition Master 5.8.1 Home Edition (free). I've found it very useful to check and often repair drives that won't mount.
Feb 26, 2012 | LaCie 1TB Minimus USB 3.0 Desktop - 301961...
I have a 500gb roco toshiba external drive. the light is on but it won't read. i tried to change it's cable but still it won't work. how can i fix it?
try and listen to the drive when plugged in, if you hear a faint skipping noise. i suspect it is a fault internally on the reader.
if you have a reciept usually the manufacturer will exchange this. as a repair is very tricky!
Jan 23, 2012 | Toshiba Computers & Internet
I`m trying to reformat pc. i get to a screen that ask for disk 1. the whole time the disk is in the drive but it won`t read it. please help
there's two possibilities
either the drive the disk is in is going out
or there's something wrong with the disk
I've got 2 hp pavilion desktop computers & I've had the drive go out & cd or dvd also
Sep 09, 2011 | HP Pavilion a1520n PC Desktop
Vaio vgc-rb30 won't read reboot disc..says can't find hard drive
check bios setting n check hard rivers iz there if u can show hard driver the problem iz hard disk and cchang it
Sep 09, 2011 | Sony VAIO RB30C (VGCRB30) PC Desktop
My PC recognizes my hard drive but it's making a ticking sound & it won't re-format. I'm running Win7 & have tried both reformat settings-NTFS and exFAT but there is not action at all....
I'm sorry to hear that your hard drive is having trouble. Based on your description of the "ticking sound" and the fact that the drive was dropped, the drive is probably physically damaged. Unfortunately, this means that your drive is failing in a way that isn't fixable; it will have to be replaced.
May 26, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
Open Questions:
Maxtor One Touch II (EO1E200) 200 GB Hard Drive Logo
54 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
