Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Acer AL1715 17" LCD Monitor
Recently, with my LCD monitor (Acer AL1715 17" LCD Monitor), I've noticed that sometimes, my monitor would go orange in places, and I can see the lines that form the images on the screen. They flash and glow orange in some parts, but they don't in others. It also changes with the background, eg. on my desktop, the middle top part is orange, while on Mozilla Firefox, the entire panel on the top (the one with the address bar, the 'File, Edit, View' etc.) is orange and some parts flash. It started about 3 weeks ago, but back then, I could just turn off the monitor for about 5-10 secs and it would return to normal. Now, however, it won't return to normal even after closing for 1 hour, and shutting down and restarting. The monitor is fairly new, about 3-5 months old. I've also unplugged and replugged the cables (there is only two: one for power and the other to connect to the computer.) The monitor is a Plug and Play, so it didn't come with any drivers. Any help would be appreciated.
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 65 Answers
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic interfered with the plug and so the plug did not seat properly. I fixed several of these monitors by shaving off some of the plastic with a dremel mototool. A hand file would probably work as well. You have to remove the plastic back to do the job.
Acer AL1715 17
Posted on Oct 15, 2014
Hi. My LCD has the same problem(in my case i have toxic green glowing areas). It starts about 2 years after i bought it, and as the time went by it was getting worse. First it appears after 3 or 4 hours of work, now it can be about 30 min. I thought that LCD is damaged by heat(after some cool-down time it got OK, but these times are longer and longer). Now I find that "reseting" from OSD menu solve this problem, but I don't know for how long :( Some drivers are there: http://support.acer-euro.com/drivers/monitor/al1715.html
Posted on Sep 03, 2007
Dude this is happening to mine! same model and all! hitting it hard seems to work for a tempory fix but only very tempory! not too good for a new monitor is it?
Posted on Aug 07, 2007
My monitor receives power, but doesn't receive signal from my computer. The green light blinks like there is something wrong and there is a faint beeping noise.
1st you separate you monitor from you Computer.
  • Now On your Monitor and check there is Faint beeping noise.
  • If there is no noise and after sometime the monitor light will change in orange colour.
  • It means there is no fault in monitor.
  • And also check Data cable of monitor is it right.
  • It means there is problem with you computer .
  • You Check the VGA Card.
  • I think there is problem with your VGA Card.
Mar 10, 2010 | Acer AL1916W 19" LCD Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Al2416w acer monitor comes on says acer then goes black
dose the standby button go orange, if it dose then the screen is going back in to standy, its possible that your graphics card is having problems, maybe if you put some more informationt about what happens then you could get better help.
Mar 17, 2009 | Acer Al2416WD LCD Monitor
Connecting an external monitor to acer 5720
I have had this before with my Dell Latitude C540/640. I don't know the ACER 5720 but here's a couple possible fixes for you.
1. Press the function key ( "fn" key, generally a blue key or blue lettering and usually in the bottom left corner of your keyboard) and press F8 (may be a different key on your laptop, again, not familure with the acer. The key usually has either CRT/LCD printed on it, or two monitors on it, one its just an outline of a monitor and the other is filled in. This will run you laptop through the three monitor options it has. (LCD - LCD & External - Just External)
2. Try closing and opening the lid of your laptop. Sounds a bit strange but it works sometimes for me. My guess is when you close you screen it would "dim/turn off" the LCD and re-opening it convinces it to turn the screen back on.
Hope this helps!
-David-
Jan 09, 2009 | Acer Aspire 5720 Notebook
I have noticed recently that the screen words flicker.
If the monitor is less than a year only, then your best bet is contact the manufacturer for warranty support.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
Jun 14, 2008 | Acer AL2017 20" LCD Monitor
Blueish flickering
Try to put speaker distance from monitor.
Try to remove the display card and fixed it again.
Then boot up your and see .
Apr 21, 2008 | Acer AL1913 19" LCD Monitor
ACER LCD Monitor
put it face down (over a clean soft cloth) and start loosing all screw, after this with a swiss knife on the edges, start loosing the plastic with patience... always unplugged...
Sep 17, 2007 | Acer AL1511 15" LCD Monitor
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
252 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
