Question about Xerox Phaser 7400/DXF Laser Printer
Xerox phaser 7400 - Xerox Phaser 7400/DXF Laser Printer
  • Xerox Master
  • 32,281 Answers
You can download the Xerox printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.support.xerox.com/support/enus.html
Posted on Feb 25, 2012
  • 2072 Answers
SOURCE: xerox phaser 7400
Remove the tray, first look for a piece of paper that has come out of the tray inside the tray area.
Make sure the rolllers are snapped into place. The easiest way to verify that is to remove another tray and compare them.
Look to see if all the switches and actuators are in place.
Make sure you hear the tray up motor running when you close the tray.
Also inspect the paper tray itself for broken items. Compare it to another tray.
Posted on Feb 04, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 7400
That is caused 99 percent of the time by the fuser.
There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
Gave the explaination so you would understand what is happening.
Posted on Mar 07, 2008
SOURCE: PRINTER ERROR
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Posted on Jan 17, 2009
  • 110 Answers
SOURCE: Phaser 7400 LCD is blank. How can that be fixed?
Once the LCD is gone blank that means you have to change the control panel. it's not difficult to change, all you have to do is remove the covers that are behind the the control panel. Once you have removed the white covers you can now unscrew the metal hinges. Then you have to insert a flat head in the small cracks behind the control panel that opens the control pane blue covers. Now you disconnect the data cable that connects from the control panel to the machine and that's it. Hope this helps
Posted on Nov 02, 2009
  • 110 Answers
SOURCE: Xerox Phaser 7400 displaying error code u60
Job Offset Home Position Sensor does not detect home position for the Job Offset Assembly.
Check the following for evidence of fault or
damage:
■ Home Position Sensor Actuator
■ SNS Harness
Is there any damage or misalignment?
parts that need to be changed if still no fixed.
Rear Sensor Board
Job Offset Assembly,
hope this helps.
Posted on Dec 17, 2009
I have a phaser 7400dx and the color alignment is off, I've heared people talk about that it is set in the main board and can be fixed. I was wondering how it is fixed?
Below is the link to 7400 documentation, the user guide on this page provides good info on color and image misregistration problems and some potential fixes ...
http://www.support.xerox.com/support/phaser-7400/documentation/enus.html
Alos, if it is a problem wioth your main PWB you may want to contact your Xerox service technician for assistance ......
I hope this helps.
Mar 09, 2015 | Xerox Phaser 7400/DX Laser Printer
Can I print to the edge with Phaser 7400
No this is phisically impossible, try a larger sheet of paper and cut it
Mar 17, 2013 | Xerox Phaser 7400DN Laser Printer
Phaser 7400 error 929
Xerox Phaser 7400 error codes 929 - Please check your Waste Toner Auger Assembly if motor won't turn and when you done the sensor test and passed the Waste Toner Auger Assembly was jammed. I just fixed this problem here, just now!
Jan 13, 2012 | Xerox Office Equipment & Supplies
On power up the xerox phaser 7400 displayed.
HI there check the fuse on the xerox machine and let me know its ok or not.
Jan 24, 2011 | Xerox Phaser 7400/N Printer
Getter "Report fault 917" on my Phaser 7400. How can I fix?
I am getting a report fault 917 error on the phaser 7400
Sep 23, 2010 | Xerox Phaser 7400/DXF Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400/DXF Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
