Question about Acer Computers & Internet
My aspire T671 won't boot passed the acer splash
  • Acer Master
  • 27,725 Answers
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps you
Posted on Feb 25, 2012
Computer wont boot all the way up
There are several reason why a computer won't boot up. First you need to figure out if your Power Supply is working, if your not a computer expert, you can try another PSU to test. Or you can use a PSU tester to test if your PSU is still working. If not, clean and reseat your RAM, if you have 2 RAMs, remove each RAM then try 1 RAM at a time, and try to seat the RAM to different slot. If not luck, clean and reseat your graphics card. If you have a built-in video port, remove your graphics card. Still won't boot? try resetting the CMOS. This might fix the problem.
Sep 07, 2012 | Acer Aspire X3200 PC Desktop
Acer aspire 6920 won't boot up
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Jul 30, 2012 | Acer Aspire 6920-6422 Notebook
My acer aspire 2920 goes black screen when I try to boot Ubuntu from USB. I thinking of reset the bios. Please help me with the procedures
Hi there. It won't be a bios problem if it allows you to selet the usb to boot from. Sometimes when you try to boot ubuntu off of a usb it gives you a black screen for as long as 2+ minutes. usb drives can be slow but if it still will not boot then it is likely a problem with the boot loader on the usb stick. I would try installing ubuntu to the usb again to see if it works. If it still won't work then there is more than one way to install ubuntu to a usb. Leave a comnent here if you still can't get it to work and i can give you some more instructions of how to make it work. It shouldn't be a problem with your computer though.
Sep 14, 2011 | Acer Aspire 9300 Notebook
Alarm beeps on startup and will only let me put in 1st digit of password beforekeyboard wont work anymore
Beeping on startup is an indication of a RAM memory problem. If you have more than 1 stick of RAM installed, try removing 1 and rebooting. If it boots up, you may have a motherboard issue that won't allow your machine to utilize all of your RAM memory.
May 14, 2011 | Acer Aspire One PC Notebook
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
I have a Acer PC. My Pc won't load past the Windows Blue Splash Screen. When I try to go in via Safe Mode, it stops at the same place. I been trying everything ... through the recovery console. With no...
remove all dervices, pci cards, modem card, usb devices ect... except for the hard drive, the cd/dvd drive and video card, if applicable. go into bios (by holding down f1, f2, f10, or delete before windows starts to load. try each, for different computers use different buttons) and disable the sould card, modem/network card, if integrated, and any integrated components which are not absolutely necessary to boot.
try to boot. if that does not work, try using 1 stick of ram at a time, and try each stick,1 at a time until it boots.
if your computer boots when stripped down, then try reinstalling/reenablind each device, 1 at a time, until you find the device that is keeping it from booting.
if your computer will not boot when stripped down, you need a new motherboard.
Nov 06, 2010 | Acer Aspire™ T180 PC Desktop
Display is black, not even the splash screen
If the RAM is not seated properly or the RAM is faulty it will cause this type of problem.
Try re-seating the RAM and if this doesn't work, remove the RAM and take the RAM to your friendly computer shop to test the RAM for you.
Next try removing the battery and just connect the power adapter and then boot up the laptop. If you do not get and LED lights then the power adapter could be faulty.
Please let me know.
Mar 05, 2010 | Acer Aspire One AOA150-1570 Notebook PC
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 3100 boot up problem
unless it is something more serious, first keep pressing F8 when you turn on the notebook and it should enter safe mode. When in safe mode select the operating system that is highlighted and then a screen will appear with options, one being 'Last Known good Configuration', highlight this and press enter. The system will reboot and start again in windows as normal hopefully. If you are not able to get a screen showing in safe mode there is something more serious wrong and it could be hard drive fault or motherboard, but if you can see the disc drive light flickering the system is loading and you may have a graphical fault.
Aug 09, 2007 | Acer Aspire 3100-1405 Notebook
Laptop Wont Boot
Does it sound like it's starting up at all? Is the problem that only the screen turns blank? You might have just disabled the standard output. Try pressing Fn (bottom left on the keyboard) and the F5 on the top a few times to see if the screen toggles back on. You might also try to run it without the battery, and on the battery only in case it's a faulty battery or power supply that causes the problem. If not, it sounds lsike a serious problem, so if there is any chance of the waranty still being valid I'd call acer support asap.
Jun 17, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
177 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
