Question about Emerson LC195EMX 19 in. TV
Will not pick up signal for cable channels - Emerson LC195EMX 19 in. TV
  • najiya jones Feb 24, 2012
    Despite running the autoscan for channels, it does not pick up cable signal even though cable cord is connected properly. it keeps saying 'no channel is registered'
  • Brett
    Brett Mar 18, 2014
    Did you get this figured out?
    Sergeant:
  • 302 Answers
Ok the first thing I would check is your settings. Most TV's have an antenna and a cable setting when you program the channels. If that does not work you might have a problem with your signal board. You can get parts for that tv at www.interliquidparts.com
Posted on Feb 25, 2012
When i mak the automatical programin for my tv (toshiba model no. CN27H95) it find nothing!!!! so there are others ways to mak manual programing to find chanels?
This feature is pretty reliable and the lack of channels may be due to the lack of signal to the set.
You must have either an antenna, a cable from a cable service or a satellite receiver connected for the set to find any channels.
Oct 24, 2014 | Toshiba CN27H95 27" TV
How to tune a tv channel
This could be too much signal.
Just to be sure though, try the set in another room where one of the other TVs works okay. This will help you see if it's a cable or a TV signal issue. If you pick up all the channels okay it's likely that that other TV point has some bigger signal losses due to the cabling.
The mux (transmitter channel) carrying the BBC signals will be amongst the strongest at each and every TV transmitter across the land. This is because the BBC and the main ITV channels have to reach about 96% of the mainland UK population in order to the broadcasters to fulfill their remit.
TV tuner sensitivity varies between brands and models. It may be that your old TV was just about okay with the signal power, but the new TV's tuner is over saturated.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 06, 2014 | Televison & Video
Why is the tv not finding channels when channels are scanned?
make sure your tv is set to pick up the signal it could be cable digital or analog channells.there should be an option for this in the menu.
Jun 04, 2012 | Scott LCT37SHA TV
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
I have a Bravia TV and have lost Channel 7
Ur tv is hook up to a antena and getting free AIR DTV broadcasting signal?Yes,tv have lost channel 7 tunning in frequencies.Go into ur tv menu goto SETUP and pick EZ or Wizard scannning might get it back,not must go into Ch. pick AIR not Cable to rescan the whole thing for picking up all free AIR DTV channels again.If tv it is getting pay Cable do the same thing,pick CABLE for channels scanning not AIR.
Apr 07, 2011 | Sony Televison & Video
Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
Jun 07, 2010 | Sharp LC-26SH10U 26 in. LCD Television
It wont pick any channels while scanning
There's several possibilities here:
1. You could have the cable plugged into the wrong port.
2. How old is the TV? If it isn't brand new, It's probably analog, and won't work if you're trying to pick up an antenna signal. For that, you'd have to buy a digital converter.
3. Do you have a cable box? If so, your TV should be set to one of the "Video" channels, not the numbered ones. Try hitting "TV/Video" on your remote until you see a picture. Make sure your cable box is on.
4. Everything else would pretty much boil down to poor signal, or broken equipment. Call your cable company if you have cable to determine if it's a signal issue.
Oct 29, 2009 | Televison & Video
Channel settings
Most TV's have an option in the menu for antenna/air and cable. I t may also be labeled digital and analog as well. You need to ensure that you have this set to the signal you are trying to receive. Some TV's have two coaxial connections at the back usually labeled antenna A and antenna B or air and cable. If your's has this option you will need to be on the correct input for the signal you want to receive. I hope this is of assistance to you and thanks for using Fix Ya.
Oct 21, 2008 | RCA F32650 32" TV
No receipt of signal or antenae
Since it has voice or sound then I don't suspect the tuner but probably the tuner does not have the 33 volts that goes through r106 location number on the board. It is a 27K resistor and can be bought for about a dollar at Radio Shack. (pack of 2or3) A repairman or someone experienced in electronic soldering and desoldering can change it easily. Could cost around $50 to repair depending on the serviceman. If it has rca jacks (red, white and yellow) The tuner can be bypassed if you have a cable box that passed these signals: audio left and right and video. Hope this helps
Dec 30, 2007 | Sanyo AVM-3258S 32" TV
Emerson LC195EMX 19 in. TV Logo
298 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
