Question about Saws
How do i attach the blade on the ryobi ws721 wet tile saw
  • 10865 Answers
SOURCE: crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Posted on Jan 28, 2009
  • 29 Answers
SOURCE: Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Posted on Mar 26, 2009
  • 31 Answers
SOURCE: RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Posted on Mar 29, 2009
  • 8404 Answers
SOURCE: Ridgid Wet Tile saw water pump operates, however
You could clean the hose ... however, I think Id get to the hardware store and get a new piece.
Clean the end with a broom straw. You could trim a small piece of the hose off. Dont neglect to clean the filter on the pump. Slide the bottomoff the pump to expose the filter.
Posted on Oct 21, 2009
al_kupchella
  • 843 Answers
SOURCE: Looking for shaft lock to change the blade on MK 170 wet saw
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Posted on Apr 27, 2010
Rigid tile saw. Can I use a wood blade?
Tile saws are designed to use a diamond blade, and to keep it wet. That's not something you want with a wood blade, nor with wood. The speed of a tile saw is much slower than a good wood saw. I wouldn't try it.
May 27, 2015 | Blade Saws
Ryobi wet tile saw 180mm
What's the model/unit of your saw? I suggest to check on manuals.ryobitools.com . You can download manual from them.
Dec 11, 2013 | Saws
TILE SAW WON'T SPRAY, PUMP AN MOTOR RUN CHECK FOR DEBRI HOW DO I CLEAN TUBING TO SPRAYER I THINK IT IS CLOGGED
Make sure pump is submerged i water
Remove tubing from pump discharge and see if pump is pumping water/ If so your tubing is clogged between pump and saw. Remove tubing and rinse out with hose.
Nov 28, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
Ryobi WS721 wet tile saw blade wont turn on start up
I just got one of these and the same thing happened, arbor spun slow and hummed. I fixed the problem by removing the motor mounting bolts I wiggled the motor and the arbor spun like a champ. When I reinstalled the bolts I checked the motor after each bolt. What I discovered was the bolts where the cause of the binding so I relieved the pressure by loosening the bolts a quarter turn each. Saw now works perfect. Design flaw!
Aug 20, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
Our on off switch insert is not here, so the saw will not turn on, any way to fix?
You can order the switch key alone, Ryobi part number 080009019088, or the whole switch assembly, Ryobi part number 080009019710, from aftermarket sites like www.ereplacementparts.com or you can go to the Ryobi website, www.ryobitools.com, and find a local or nearby service center that either has the parts or can get them for you.
Jul 03, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
How do i find owners manual
Try here http://services-uk.ryobitools.net/accueil.asp
Jun 24, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
Apr 27, 2010 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Ryobi WS720S wet tile saw. Will not spray
Check the pump operation and pump intake screen for plugging. Make sure the water reservoir is not full of cutting debris.
Jan 24, 2010 | Saws
Wet saw not cutting material completely
It might need a new blade. But try putting an old tile or offcut behind the tile you are cutting. Make sure the table surface is clean and flat. Residue tends to build up around the front of the blade which could cause the tile to crack. The ryobi's have a habit of water getting into the motor and the bearing destroys itself. Next time you take the blade off, take of the blade support and put bearing grease behind the rubber washer. I've blown up two this year until I worked out what the problem was.
Apr 25, 2009 | Saws
Apr 22, 2008 | Irwin Miter Saw Laser Guide Attachment...
Saws Logo
69 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
