Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Figidaire gallery model FRS24ZGH after running for a little while it freezes up
2 Suggested Answers
dcp2
  • 63 Answers
SOURCE: freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Posted on Jan 28, 2008
The Gallery app freezes when I try to look at the pictures from the SD card. How do I get it to work?
try clearing the cache for your gallery or force close. got to settings then apps or app data then go to all apps just after running apps. search thru all apps till you get to galley there you can clear data and cache for gallery after that force close it then go back to gallery to view your pictures the way you normally would see it it works.
Feb 04, 2016 | Samsung Galaxy Prevail LTE White Boost...
Where is the thermostat located on a frigidaire gallery model GLRS2642AQ6 Electrolux side by side. Keeps freezing up even after turning down both side to just cold.
Hi this is most likely the damper assembly not the thermostat, the damper assemly is on the left side of the refrigerator compartment in the very top corner up there, sometimes depending on the model this damper runs 3/4 of the length of the left wall there. This entire assembly needs changed.
Sean
Mar 28, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have figidaire gallery dryer model fsec748gf d'ont start.i heard timer motor did tic,tic but the electrical motor not turn and did not smell burn. thank you for your support. Michel
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 05, 2011 | Dryers
I have a Figidaire model # FRS6R5ESBL. When it defrosts the water just drips down to the bottom of the freezer and freezes, then the next time it defrosts it runs out onto the floor. Why is this water...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Frigidaire FRS6R5ESB
Electrical panel went blank. Hence can't operate the oven. Stove works fine.
Hi. Interesting. My Figidaire Gallery Professional gas stainless went blank 2 days ago. Model FGF379WECS. So I'm googling...
Your Service Manual is located at (document #2 in link):
http://www.retrevo.com/support/Frigidaire-GLEFM397D-Ranges-manual/id/2367bh351/t/2/
Part Number
316418704
Description :
Clock/Timer, electronic, w/mini oven, ES510
Rick
May 15, 2010 | Frigidaire Gallery GLEFM397DS Electric...
Need to remove the front
there are two screws on the back of the lid take those off then slide the lid off remove the screws that hold down the control the the screws on the inside of the cabinet that hold the front panel in place once removed the panl will pop off
Sep 09, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Freezer not freezing
sounds like your loosing freon.
Jun 09, 2009 | Refrigerators
MY FIGIDAIRE GALLERY SERIES MICROWAVE IS LEAKING BLACK OIL
hi my name is mark, if nothing boiled over in the microwave. the oil could be coming from a capacitor in the microwave oven. i would call for service before it fails.
Mar 16, 2009 | Frigidaire GLMV169D Microwave Oven
Freezer not cold enough to freeze items solid
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
54 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
