We have a Rockford fosgate p3002 model. The amp fuses keep blowing and the protect light is on.
    President:
  • 624 Answers
It most likely has a blown channel. It is going into the protect mode. If you have a multimeter I can guide you thru the process of figuring out which channel is blown and how to repair it. It will require, as noted above, a multimeter as well as a soldering iron, solder, solder wick and then the purchase of the bad parts. If you do not have this equipment there is no way for you to fix this yourself. You can always take it to a service center for repair if you are not able to do it yourself.
I have fixed many Fosgate amplifiers and can assure you there is no easy fix for your amplifier. It will require the replacement of parts.
Let me know if you are willing to try it yourself and I will help you as much as possible.
Dave
Posted on Oct 28, 2008
  • jachris122 Jan 27, 2012
    Dave, please contact me, as I have the same issue with my P3002
Rockford Fosgate P3002 stopped working
push down and up on your subs and see if they make a starching noise, if they do then they are blown. take a test light to the amp, on the power and the remote and see if it lights up. if it does then turn the amp down and with a small speaker plug it in to the speaker outs on the amp and see if it plays if not then your amp is bad.
Nov 26, 2013 | Rockford Fosgate Punch P3002 Car Audio...
My rockford fosgate T1 amp blew a fuse and now protection is on
Chances are that more than a fuse went. I would follow (internally) the path of the wires from the speaker you mentioned - inside the amp. This should bring you out to the main amp. I think you will find that whatever powers that channel is faulty.
Apr 10, 2013 | Rockford Fosgate FAP T1 Amplifier
I just need to know if the crossovers that come with the T1652-S Rockford fosgate have fuses . to prevent the speakers and tweeters from being burn out. or for safety purposes
The fuse like componets in the crossover are not fuses and do not provide absolute protection from the speakers blowing. As you turn the volume up you will notice that these fuses will begin to light up along with the music. Whats happening is as they light up they create resistance to help prevent the speakers from blowing.
May 15, 2011 | Rockford Fosgate T1652S Car Component...
Rockford Fosgate Punch P325.1 Amp keeps blowing fuses every time I start the car. What is going on?
well if the amp works with the car off and when you start it the fuse blows then you may have alternator issues use a volt meter to check battery voltage is not above 14.5 volts
if the fuse blows when the amp turns on then most likely you have a shorted output section in the amp.
Mar 18, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Rockford Fosgate punch protection light
power it off, then on...check you're fuses. unplug the car battery and try again. good luck.
Sep 05, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Amp
There is no reset button. If you disconnect all of the speaker wires from the amplifier's speaker terminals and unplug the RCA cables, does the protect light still come on (I assume that you've already replaced the fuse)?
Jan 12, 2008 | Rockford Fosgate P6001BD Car Audio...
Rockford Fosgate P3002 Amp
what are the color of the lights that stay on.red= protect/ green=on.if the amp has little sound it probably still working,check deck output volume(rca)
Aug 22, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Blowing fuses
check your car battery and check your ground and check your power wire for any splits or cracks
Nov 22, 2006 | Rockford Fosgate Punch P3002 Car Audio...
78 people viewed this question
 Grubhead
Grubhead
