Question about Memorex Televison & Video
I want to set up a Sony Blu-Ray BDP-S185/BX81 to Memorex DVD/Home theatre System and TV. The Memoresx does not have HDMI but has Audio in I can not get audio from the surround system
Not sure of the Memorex Model but I can check tomorrow. Helping a buddy. It is a unit in an RV, it is a DVD with surround sound. We connected the Composite Video from the Blu-Ray to the TV and audio out to the Memorex. (for a test we also connected the L&R Audio from the DVD to the TV still no luck. The HDMi connection from the Blu Ray to TV works well but we do not get surround sound. The test with the Composite Video/Audio was completed with the HDMI Disconnected. TheMemorex does not have an HDMI connection.
SOURCE: Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Posted on Oct 18, 2007
SOURCE: Memorex MVD2027 DVD Player - Remote doesn't work
haha I have the same problem.
Posted on Jun 09, 2008
SOURCE: Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Posted on Dec 11, 2008
i just hooked up my sony blue-ray to my samsung suround sound.but i cannot get the sound to work.
Posted on Dec 14, 2008
SOURCE: Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Posted on Jan 10, 2009
How to turn off child lock feature on S Sony DVD BDP - S185.
The child lock features / parental control features are explained on page 17 of the manual. You have to know the password or otherwise reset the player. https://docs.sony.com/release/BDPS185_BX18.pdf
Aug 10, 2014 | Sony Bdp-s185 Blu-ray Disc Dvd Player...
Why my blue ray dvd BDP-s185 cant eject disc. it say '' the eject key is not available''
you might have the tray lock function turned on. TRy holding the play button for about 10 seconds to see if it unlocks
May 06, 2014 | Sony Bdp-s185 Blu-ray Disc Dvd Player...
I am trying to hook up a Sony BDP-S360 via HDMI
I don't know what kind of TV you have, but on some TVs the HDMI inputs have to be enabled via the TV setup menu. Try looking at the setup status.
Dec 27, 2009 | Sony BDP-S360 DVD Player
How can i connect the system to a new sony bluray
use your tv as a common connection in your theatre system. Connect your hdmi blue ray player to the tv,connect the audio output of your tv (rca style cables -red&white) or if your tv and audio system has optical you can use that also.
Dec 23, 2009 | Panasonic SC-HT500 System
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
I have bouight a samsung home theatre system that comes complete wiht a DVd player - i also have a samsung blu ray player - naturally ithought they would be compatible!! how wrong i was!! the connections...
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
Jun 19, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Oct 01, 2007 | Sony DAV-HDX500 System
Televison & Video Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
