Question about Sta Rite STA-RITE POOL PUMP LID, FOR 6 TRAP- 16920-0011
Best tool to open the 6 inch lid 16920-11 of the Sta Rite max-e-glas strainer basket
  • 88 Answers
SOURCE: service heater lite comes on
yes you can ,go to starite.com,when the page comes up at the very top there is a button that says owners manuals,just click on that and you will probably have to have your model #.hope this helps.
Posted on Dec 06, 2008
  • 83 Answers
SOURCE: sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Posted on Jul 10, 2009
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
john224
  • 1378 Answers
SOURCE: I have a sta rite dura glas 1HP pump and can't
Lock the shaft at the end where you electrical connections are made (disconnected of course!) and spin it off counterclockwise.
Posted on Aug 11, 2009
  • 3600 Answers
SOURCE: Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Posted on Sep 29, 2009
What bearings do I need for a sta-rite JWPAS5F-2A4
there is a possibility it might use the most common 6203 2rs or 6203 2rs 5/8 bore, these are a hard motor to work on, you must be careful pulling the front bearing as it is easy to bend the threaded portion of the shaft, and breaking or bending/breaking the start switch is always a possibility, and these parts are near impossible to find ! I wish you the best of luck... jay
Jun 16, 2014 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
How to clean or remove impellers in sta rite pool pump
remove band clamp then remove the part over the impeller then the reverse screw holding the impeller on then unscrew the impeller regular thread hold the back of the motor shaft take apart remove old install new and re assemble
May 16, 2014 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Wiring schematic for MTB217 cooper b line
I would suggest taking a closer look at the motor name plate. I am not familiar with a 120/240 three phase service. When I checked the web it shows: Voltage 115/230 (that is single phase), Max Amps 115 Volts = 19.2 Max Amps 230 Volts = 9.6 , Single Speed, Square Flange, RPM = 3450, Threaded Shaft, Frame = 48Y Used on the following models: Sta-Rite Max-E-Glas, Max-E-Glas II, Dura-Glas, Dura-Glas II, Dyna-Glas, Dyna-Max Pentair Whisperflow, Pinnacle and Anthony AR2 Series. You should also show what voltage you are connected to.
Mar 14, 2014 | A.O. Smith SQ1102 Pool Pump Motor
I have a Sta-rite Max-E-Glas system in my pool. Every two to three weeks I have to dis assemble the pump section to remove small cedar fronds from between the impeller and the difuser. This is becoming...
Your local pool store sells a bag that goes inside the basket in the pump. This should stop everything(but the water) from getting in the impeller.
Jun 13, 2011 | Sta Rite Pool & Spa
The motor is running OK, but it won't pump the water
a suction leak will cause the pump not to prime... check the lid gasket, lid for cracks,pipes and valves. you can rap the fittings with electrical tape, to help you locate leaks.. a shaft seal is a good start, this will allow you to ree the condition of the impeller . it may be plugged, also see if there is cracks in the hair basket it will allow trash to get into the impeller
Mar 22, 2011 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Need bearing within PN C103-137P1 , higher assembly would be P2PA50-120L
most of these are 6203 2rs c3 bearings used in this motor. here is a picture on how to remove your pump for service, i would suggest professional repair to avoid extra costs.. just search your area for yoour local pool pump motor repair guy..remember to prime the pump after any pump repair ..jay
Sep 21, 2010 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Sta-Rite Dyna Glas Pool Pump
debris may have gotten into pump or pump is air bound need to check pump first try to bleed pump if water comes out and not pumping hard possible burnt up impeller or seal
Apr 03, 2010 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Pump starts and stops frequently . pump will start but not run. Sounds like it will not get up to speed before it stops.
That sounds like the pump is cycling. Is there air in the pump basket or is it full of water? If there is air in the basket, you have a leak somewhere. Could be the lid has a crack, or the o-ring, under the lid has gone bad.
The pump motor may be going out on you also. If it is hot to the touch, there is a safety feature in the pump that will shut it off before it becomes too hot.
Jun 30, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Apr 13, 2009 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
The suction and water flow is greatly reduced
It's possible to wear out the impeller. To remove the impeller: after removing the motor and impeller from the housing, you remove the cover from the electric end. Carefully find a flat on the shaft that usually fits an open end wrench close to where the shaft goes into the motor. Not on the end of the shaft where the spring thing is. Hold the shaft with a wrench while turning the impeller, don't let the wrench break anything. Double check the threads on the new impeller to see if they are left-handed. The impeller should unscrew in the direction of the motor's rotation.
Put in a new seal while you're there.
Apr 10, 2009 | Sta Rite Max E Glas Energy Efficient Pool...
Sta Rite STA-RITE POOL PUMP LID, FOR 6 TRAP- 16920-0011 Logo
225 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
