Question about Delphi SKYFi3 Satellite Radio Receiver
My Delphi Skyfi3 audio output stopped working
When you plug in head phones you get no sound. When you connect the house base to stereo with RCA jack there is no sound.
  • raycroskrey
    raycroskrey Feb 24, 2012
    Other wise it works just fine and plays just fine in my car using FM mode.
3 Suggested Answers
SOURCE: trying to update firmward on Delphi SKYFi3.
I have the same problem and the person I just spoke to said there is definitely a problem with the radio itself and told me to return it to the store! I told her I bought it five months ago and asked if that would be a problem and she said it would not. This should be interesting...
Posted on Apr 27, 2008
SOURCE: Delphi skyfi3 won't turn on, the screen is white.
Press both the MODE key and the Volume control for a few seconds and the unit will re-boot.
Posted on Nov 07, 2009
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
I have an older home stereo system that i would like to connect to my vizio tv. I have a 3.5mm audio to rca plug. Coming out of the headphone jack on the tv, it plays no sound out of the system. Although...
I suspect what you're wanting to do is take the audio output from the TV and run it through your stereo system to leverage the large speakers. Correct?
I suggest using the RCA audio jacks (red and white pair) on the back of the TV. Most TV's still have these. Some are tied to a specific component, and some are general for all sound coming out of the TV. You connect this to the input RCA jacks on your stereo system.
The headphone jack on the TV could also work, but I suspect it may have a low level output. I don't understand how you say your MP3 player plays fine through the headphone jack, as that's an output, not an input. Unless there's some other jack?
Sep 22, 2013 | Vizio 29in Class LED 720p TV - LED TVs
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
I purchased an adapter for the mini jack - based on the sales associate advice - to connect my 3G iphone into my Sony DE595 headphone port. I decided to dbl check here before I plug it in. I see I...
Dont do it.
The jack on your phone is an Output. So is the headphone jack.
You need a stereo mini plug to (2) RCA type male plugs.
Then plug that into the AUX or CD jacks in the rear of the Sony
Sep 30, 2010 | Sony STR-DE595 5-Channel Amplifier
How to play my ipod through this stereo
USER GUIDE
This is the quick and easy way to adapt a standard stereo 3.5mm (1/8 inch) sound output into standard RCA plugs. Ideal for connecting your MP3 Player with a 3.5mm plug to VCR's, TV's or anything else that has RCA stereo sound inputs.
General Features:
- Fits standard 3.5mm (1/8") stereo phone jack
- Gives you two male RCA (left / right) sound outputs
- Great for converting a headphone2_bing.gif jack to standard RCA sound outputs
- 6 foot length
- Straight cable (not a coiled cable)
Generally these connectors cost between $1.00 to $5.00
Pictures to help you find them
Search google for headphone to rca adapter for more info
Hope this helps
Feb 05, 2010 | RCA RS1286 CD Shelf System
Conecting to souround sound
find the audio output jacks. Should be one red and one white, that say output by it. You can get the RCA Audio Jacks that plug in to the tv audio output jacks to your receiver or stereo INPUT jacks.
Aug 05, 2009 | Televison & Video
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Delphi SKYFi3 Satellite Radio Receiver Logo
44 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
