Question about Boating
I have a Jabsco Ray-Line Searchlight model 61026 & need a wiring diagram or manual
Light works & was doing up-down movement but not rotating. lamp has 7 wire cable brown oeange black yellow blue grey green, orange & brown do spot/flood light when black is connected to oposite pole but can't get what wires do rotation/ up-down or which should be positive feed. I think I really need a wiring diagram as it has dual controls also. Help please!
  • bryan sg
    bryan sg Nov 11, 2013
    Did you ever get a response to your Rayline 61026 query?
  • bryan sg
    I have same searchlight with similar problem.
MNfisherman
  • 11896 Answers
SOURCE: 1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Posted on Jan 17, 2009
SOURCE: there is 6 coloured wires coming out of the bottom
problem solved
Posted on Jan 19, 2010
SOURCE: Proper wiring from NMEA
I want to interface my Garmin 182c GPS with my B&G Hydra 330 gages. Both support NMEA 0183. How do I do this?
Posted on May 12, 2010
sulavaca
  • 1007 Answers
SOURCE: I need a radio wiring diagram for a Holden Commodore LS 1991
Regardless of colour coding, please follow the following instructions (require multimeter):
Note: Attach multimeter earth wire (black) to the vehicle body. Convenient places may be the metal ignition barrel, the vehicle's car arial plug, cigarette socket body etc.
1) Testing for voltage with key out of the ignition, locate the permanent positive wire. This will wire into the yellow wire on your new stereo. The yellow wire circuit powers the stereo's memory.
2) Testing for voltage again. This time you are testing for a wire which only offers power with the ignition turned on. This one will wire into the red wire on your new stereo, and will power the unit only with the ignition on.
3) Now you know which your vehicle's positive wires are you can now test for an earth wire. Switch the multimeter to the resistance setting. There is one setting which will allow a buzzer to sound once you find continuity. With the ignition off test each wire until you get a buzz and a low resistance reading. This should be your earth wire. Double check this with the ignition in the on position. It should remain the same. If it changes to a positive with the ignition on and with the vehicle's lights switched on, then this is the dimmer feed for the stereo's screen. If you unintentionally found the dimmer feed, then you can ignore this wire, and search again for a wire which only offers an earth.
Now you have your power and earth wires located and can wire these into your stereo before continuing.
4) Next you need to use the stereo's balance and fade controls to allow only one speaker output to work from the stereo. So let's start with Left Front speaker output only. turn the stereo volume to mid way so that you can hear when you have connected to the right speaker. bare the remaining wires on the car side and test combinations of the remaining wires until you find the front left speaker of the car. Wire your stereo's wires once you find the correct connections.
5) Repeat the above steps with all remaining wires, remembering to adjust your stereo's balance and fade controls to only allow one speaker output at a time, to ensure the only one possible channel to work and help you identify which of the car's wires power the speaker you have selected.
Before re-assembly of the dash panel, check that your stereo and all functions work properly, being sure to use your fade and balance controls again to test all speakers individually.
If you want to be extra careful and wire the vehicle's speakers positive and negative, according to your stereo's outputs, not that this makes much difference on standard stereo arrangements, then follow this next step:
Make sure you can see the speakers themselves and connect a 1.5 volt AA or AAA battery to the speaker wires. If the speaker's cone pushes forwards, then the wire you connected to the battery's + terminal is indeed the positive wire and should be wired as such. If the speaker does the reverse, then you have the wires the wrong way around. Do not repeat this test for extended periods as damage may be caused to the speaker circuit.
Tip: Always solder all connections and insulate well from each other. Stereo connections can corrode over time and are prone to movement behind the dash. Poor connections may cause faults and low quality sound.
Posted on Oct 30, 2012
Jabsco 3270-200 repair manual
go on line --google --and type in jabsco water pumps repair manual. If you find a free down load select the workshop manual and you will get what you want
Apr 20, 2013 | Jabsco Boating
Need wiring diagram for jabsco 135 searchlight
I have an older unit, but this might help...
Thick Black wire is Earth or Ground
Thick Orange wire is Spotlight feed +
Thick Grey Wire is Flood feed +
Green and brown wires are motor up/down
Yellow and Blue are motor Left and right.
Sep 23, 2012 | ITT Jabsco Jabsco 135 Sl Remote Control...
Where can I buy the reflector for a ray-line #41120-1110
Did you ever find a source? I am looking for a bulb for this same unit, and also a gear mechanism for tilt.
Apr 23, 2012 | ITT Jabsco Jabsco 135 Sl Remote Control...
Jabsco 146sl repair
I am looking for a manual for a jabsco 60080-0012?
Jan 19, 2012 | Jabsco 60080 0012 Marine 146sl Remote...
Need bulb for 41120-2110
Did you ever find a bulb? I need one too.
May 31, 2011 | ITT Jabsco Jabsco 135 Sl Remote Control...
Light turns on and moves up and down but will not go from side to side only clicks, I removed the light and the gears looked good. could it be the control itself?
Chances are that it may be a ceased motor assy.
I had same problem & solved it by replacing motor assy.
Suggest unwire it & remove from unit and apply 12v to terminals (either way round)
If the gear wheel does not turn slowly then that is where your ploblem lies.
Replacement motor not excessively expensive.
Aug 03, 2010 | ITT Jabsco Jabsco 135 Sl Remote Control...
I have a jabsco 8'' searchlight, it slews however the light went out, is this replaceable or is a whole new unit needed.
Seems like it MUST be replaceable. Look it up on the net. http://www.google.com/search?source=ig&hl=en&rlz=1G1GGLQ_ENUS331&=&q=jabsco+searchlight+parts&aq=1&oq=jabsco+searchlight
Jun 16, 2009 | Boating
Boating Logo
732 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
