Question about JVC LT Televison & Video
Jvc plasma monitor with picture but no sound from internal speakers
Great picture but no output sound form internal speakers
    Sergeant:
  • 302 Answers
OK i would check the obvious first. Check your controls to make sure the speakers are turned on. The next thing I would check is your speakers you would have to take them out and inspect them physically and if you can take the out and plug them into a receiver or something that has oudio out. If all that is good then You signal board migh be bad.
You can get parts for that tv at www.interliquidparts.com
Posted on Feb 25, 2012
pgh_pa_guy
  • 2992 Answers
SOURCE: 61 inch pioneer plasma audio hook up?
I checked on Pioneer's site and couldn't find literature for this model, but did find the product information sheet for a model PDP-614MX. It may be similar, but no promises. This model has no audio output available, but does accept several audio inputs. It shows speaker terminals on the bottom and claims a 9-watt output for each channel. Speakers that mounted on the sides were available as an option.
This monster was originally designed for professional use (stores and such) as strictly an output display device. Probably the best solution would be to use this to display the video, and run the audio output from the source (DVD, satellite receiver, etc.) to a separate amplifier to drive your speakers.
Posted on Feb 07, 2009
Warf135
  • 137 Answers
SOURCE: When I use the headphone output jack (to drive a powered subwoofer), the default internal speaker audio output is disabled, leaving me with only the subwoofer output. How can I use both the internal
Your best option is to use a seperate amp with sub output from the audio outputs on the back of your TV. use this amp to power the sub and a good pair of speakers, and you'll have quality sound.
It is possible to prevent the TV's internal speakers from cutting when you use the headphone socket, but it means going inside your TV, and if your not skilled, you can easily blow your TV (and yourself) up. You just need to re-wire the headphone socket on the TV to stop it cutting the internal spaekers.
Posted on Oct 06, 2009
supermn4u
  • 16 Answers
SOURCE: NEC 42VM2A plasma tv switch to internal speakers
I don't know if you have the owner manual for this T.V. or not but if you need one you can download a manual at www.devicemanuals.com/guide/Television/ Hope this helps!
Posted on Feb 16, 2010
  • 117 Answers
SOURCE: My Westinghouse LTV 19w3 is not giving a picture
tuner might be bust
Posted on Apr 18, 2010
  • 5 Answers
SOURCE: jvc plasma monitor gmv42e can not get a picture
I have just been given one of these, it not a TV, it is a monitor, and so does not have a TV tuner or a scart (it was made for professional use).
You need to plug it in to a DVD player/Freeview/Sky box using alternative means to a scart lead. You can do this by using a scart to 3 BNC lead and plugging this in where it says 'Component/RGB B'. This carries the picture, but not the sound. To get the sound you will need to plug a twin phono lead into the red and white audio plugs.
Alternatively, you can use the 'Video in' yellow socket to connect to connect to a DVD etc. The guy did this in Maplin's and it seemed to work.
JVC professional were really helpful on the phone, ask for their technical department, they can also email you the manual.
Posted on Jun 24, 2010
Jvc av 20420 no sound
Check and replace damaged component/s at the audio output section circuit. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Mar 07, 2013 | JVC AV-20420 20" TV
I have a jvc kd-lh300 that would come on but no sound. i try hooking the wires to individual speakers still nothing, i checked all the fuses nd still nothing..so what do u guys think?
It sounds like you may have a bad internal output ic. If you know how to access the menu, some decks now have the option to turn off the internal output ic. I'm not familiar with that particular deck, so I couldn't tell you for sure.
Jul 25, 2011 | JVC Sirius KD-LH300 CD Player
I have a plasma Samsung with picture but no sound
Internal sound board/amp is probably bad. But make sure that the speakers were not turned off in the sound settings menu for the television. You could try hooking up and external reciever to the audio output jacks of the TV and see if you get any audio from there. If you do at least you can still get sound from your tv...even though it is not from the internal speakers.
Sep 26, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
No audio output from jvc cd receiver kd-sx770
The internal amplifier is at fault.
This will need to be repaired by a electronics repairman.
There is no end-user fix.
You may choose to, instead, use the RCA low level outputs and install a dedicated amplifier to power your speakers.
Verify the fuses on the radio are good, and that there is not a blown speaker causing the internal amplifier to shut down.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | JVC KD-SX770 CD Player
Sound Problems with JVC AV-35BP4 TV
The audio output stage for the speakers may have failed in the TV set. If the set has an earphone jack, it is also possible that the jack has a fault (very rare, but I have seen this).
Are there external speaker outputs to try other speakers?
Jerry G.
Apr 29, 2008 | Televison & Video
JVC TH-L1 problems....no sound
Almost the same problem. HDMI connections good, sound and video through monitor (LCD TV) , but no sound from the JVC unit speakers.
Dec 29, 2007 | Audio Players & Recorders
No Sound on TV??
I would borrow a set of external speakers to see if I could get sound from the sound circuit at all, if not, then it sounds like the repair shop.
Jul 28, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Televison & Video Logo
93 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
