Question about Video Game Consoles & Games
Dark colonymultiplayer i have cable and wireless connection how can i connect two wireless computers to multi play
  • 55 Answers
If the game uses serial codes to install or use the game, you need to have purchased 2 copies. Then you can either connect them with your (i'm assuming is a lan) cable. OR Download hamachi (you should use version 1.0.1.5) and create a network. Hamachi is a program that creates a virtual lan cable. You can download it here: http://www.filehippo.com/download_hamachi/2114/
Posted on Oct 28, 2008
  • Chris Fritz
    Chris Fritz Oct 28, 2008
    Internet is needed for hamachi to download, but no for tha lan play
I CAN NOT CONNECT WIRELESSLY?
My MFC-490cw connects to the wireless internet and so does my computer. However I am still unable to print, scan, etc... The status monitor claims it is offline. I recently switched routers and it seemed to cause the problem. Any ideas on a fix?
Feb 18, 2010 | Brother MFC 490cw Color Inkjet...
The ploblem is In need the solution of wire less network to build in the big house.
I presume you need Internet access in this house using a wireless network.
The best place to locate the wireless router is in a spot centrally located where the radio signals can reach the rooms where the computers are located. The DSL or cable modem/connection would also need to be in this area so it can connect to the wireless router.
If the wireless router is in a multi-storey house and the floor slab and walls are concrete and/or brick, then the radio signals will be impeded and the signal strength to some rooms will be weak.
In such circumstances, it maybe better to install network cables from these rooms to the wireless router, or install wireless access point repeaters to increase wireless coverage.
If you are not sure how to setup and install this network, then I suggest you get help from a computer savy friend or from your computer friendly shop.
Nov 04, 2009 | Adapters.com Computers & Internet
Always lose connection while playing playstation 3 online. Sometimes my computer displays a launchmodem error when trying to get on the internet. If I unplug the modem and router, it works again.
Please give some information on your router and modem brand/model, also what type of connection do you have, cable, dsl, etc. Go to speedtest.net and post your upload and download speeds as well.
Are you connecting to your play station wirelessly or through network cable directly to the back of the PS3?
Depending on your speeds your connection could be overloaded by the high demand the PS puts on your internet connection, or if you are wireless you could be in far range from where the router is located. Hope this helps. The extra information might help.
Sep 17, 2009 | NetGear WGT624 Wireless Router
My XP computer is a wired connection to the modem. The XP computer is supposed to be a wireless connection to the modem. That said, why is it that when setting up the router, I am instructed to plug in...
It's not really required to plug in your PC via ethernet cable to the wireless router in order for you to configure it. It is however, recommended to connect it via ethernet cable initially so that when you changethe wireless settings on the router you wont get disconnected. Please note, that when you connect your PC wirelessly all wireless settings should match (Wireless Name/SSID, Wireless Security (WEP/WPA keys or passphrase), Wireless MAC Filtering).
Jul 14, 2009 | Linksys WRT54G2 Wireless Router
Game server and my IP address
First option is to forward ports where your friends can connect to. The second option is to put your computer in DMZ. These options can be found on the router settings.
Jun 17, 2009 | Apple AirPort Extreme Wireless-N Wireless...
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Internet
First you need an internet connection, wireless or network cable.
For wireless:
You need the XBox 360 wireless adaptor.
Follow instructions to plug it in, then turn on console.
Go to the Dashboard.
Go to Console Settings.
Then Network Settings.
Then Search for a Network.
When you find your network, select it.
If you have a network code, such as WEP, enter it when prompted.
Now, whenever you turn on your XBox and have the wireless adaptor plugged in, it will automatically connect to your network.
For cable:
Plug in the cable to your console at the back.
Then follow above steps if it doesn't automatically connect you.
To play with mates, you need to purchase an XBox Live Gold Membership.
To do this, you must create an account after connecting to the internet.
To create an account:
Dashboard
Create Account
It will ask you to set up XBox Live and to pick a name.
Pick your name and connect it with a Windows Live account such as hotmail.
Follow steps to input information.
Payment can be automatic to a credit card number or, you can purchase XBox Live Membership Cards at most electronic stores, and input the codes.
You get one month free trial just for signing up.
Now to play:
Find out your friends' gamer tags or XBox Live name just as you made yours.
Push the XBox Guide button in the middle of your controller.
Select Friends.
At the top, add friends.
Input their gamer tag.
When they accept your invite/request, you can invite them to chats and games.
Pick your game, follow the instructions to play a multi-player game over XBox Live with your friends.
Have fun.
Dec 28, 2008 | Microsoft Xbox 360 Console
Brother printer mfc 240c
no. you should buy a mfc 440cn / 465cn or better -if wireless- a mfc 865cw
May 15, 2008 | Brother Multi-Function Center MFC-240C...
MPEG2
MPEG and MPEG2 are video file formats. Although the theoretical maximum data rate for wireless connections is 11 megabits per second (Mbps), most communication occurs at about 4 or 5 Mbps. To play correctly, a MPEG2-encoded file can require between 4 and 6 Mbps of bandwidth, depending on the size of the image. For example, you might be able to play a low resolution video over your wireless connection, but you're likely to experience stuttering or image corruption when playing a DVD-quality video over the same connection. To prevent this problem, copy the MPEG2 files to your computer over the wireless connection, and then play the files locally.
Feb 16, 2006 | Belkin Wireless Cable/DSL Gateway Router
Video Game Consoles & Games Logo
211 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
