Question about Candy Dryers
How do I find the capacitor on my candy GOC218
I need to replace the capacitor on my Candy GOC218 but I can't see it and I can't take the sides off?
SOURCE: Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Posted on Oct 12, 2008
  • 1462 Answers
SOURCE: candy cic 60 keeps tripping electric
take cover off fan and see if there is signs of water there. a common cause of tripping is that water is thrown up from the fan onto the element.
get back to me if you find this
Posted on Aug 13, 2008
SOURCE: candy drum bearing replacement
Hello
This is fairly straightforward but little hard work to remove and fix. If you have Candy Washing machine such as model CE430 which is fully automatic electro-mechanical with AC motor , the replacement will be as follows that I have done successfully
1. Remove the belt and motor, then remove the hex nut on then drum pulley. But pulley may not come out. It is suggested to remove the hex nut whiled drum on the frame because it is easy to remove while it is on the frame.
2. Take the complete drum assembly out of the washing machine frame.
3. Leave the drum assy on a bench with pulley side upward, use puncher to tap onto the center of the drum spindle, make sure that you will not damage the screw threads on the spindle. the spindle should go down the pulley should pop up.
4. Then keep punching until drum spindle and the “Y” arm assemble comes out.
5. Now you will have the pulley and drum and Y spindle removed. the 2 bearings and water seal still in the drum casing.
6. Use rust cleaner chemical or spray to dissolve the rust off. Then use either bearing puller or use iron puncher to tap on the bearing gently but hard , may use 1kg hammer and take each bearing out. The inner bearing will come out with the water seal.
7. How to get the spare parts; these parts are very common in this geographical region ( Asia). You can buy generic parts. Get the mechanical specifications on the bearing to buy the bearing. The water seal which is generally referred as oil seal, look for specifications such as specs will have inner & outer diameter and the height ( width) ie 22 mm, 40mm and 10mm for water seal of the Candy CE430. Make sure you have the exact shape of the water seal as the original one.
8. Install back the new parts: you need to smoothen the spindle and clean the area as well. to have less friction , smoothen the spindle surface using sand-paper, it will be easy to press the bearing and the spindles.
9. 1st you install the bearings. You need to add thick lubricant in between the inner bearing and inside of the water seal. Then insert the water seal as well.
10. The drum spindle can be inserted to the bearing, you cannot use iron hammer because it will dent the drum, you need to push and may use wooden plank warp with thick cloth like towel to batter on to the center of the drum gently, if the spindle is smoothen properly it should go in with out a hassle. Make sure that drum rotates freely, then pulley can be installed.
11. The drum bearing replacement is completed
12. Re-install the other parts back.
Pub
Posted on Nov 18, 2008
SOURCE: Candy CPCA270FFK Thermostat replacement
if your refrigerator is in warranty than contact your service authority......or if you had purchased it by your own than ...... my friend! the thermostart does'nt have any warranty
Posted on May 14, 2009
SOURCE: CANDY TUMBLE BRYER BELT
i changed the belt on my candy civ 100 but it wont turn on yet all the wires seem to be connected and the fuse in the plug is ok
Posted on Oct 17, 2009
MY CANDY CONDENSOR DRYER STOPS AFTER 2 MINUTES
try replacing the capacitor......round silver unit about 3" long sat next to motor.........
cheers
Nov 17, 2016 | Candy Dryers
Can anyone tell me where I can get a capacitor for my Candy Condenser dryer model GOC218-80
http://www.buy-spares.ie/candy/tumble-dryer/catalogue.pl?shop=candy&path=111515
Jun 30, 2015 | Candy Dryers
Where can I buy new loading baskets for my DWI 160 dishwasher?
These come as several parts. Not sure if all are available anymore as Candy parts. But you can get replacement Hoover parts to fit.
Main basket from Candy
Candy DWI 160W UK Dishwasher Basket
Cutlery basket from Candy
Candy DWI 160W UK Universal Cutlery Basket
The Upper and Lower baskets may not be available from Candy but Hoover replacements are
Candy Use HVR41022779 Lower Basket
Best to ask Candy support to provide pictures of the parts for comparison with your model or purchase or a refund policy if not suitable.
There is another site worth checking (but prices seem high)
CANDY DISHWASHER BASKET LOWER for DWI160W UK
Sep 23, 2014 | Candy Dishwashers
Nostalgia electric hard candy cotton candy manual
I believe you are looking for the Manual for the Nostalgia Electrics PCM805 Hard & Sugar Free Cotton Candy Maker which can be found online here:
http://nostalgiaelectrics.com/manuals/PCM805.pdf
Jun 17, 2012 | Nostalgia Electrics Hard Candy/Sugar Free...
Candy DWI 160 dishwasher water not heating.
the only things is the TIMER: CAN BE FAULTY, maybe is stuck, not completely the cycle.
Clean the contact with special spray, loose the wires, replace burn wires, or break wires.
May 08, 2012 | Candy Dishwashers
Candy grand o go482/2-80 very noisy when spinning
The manufacturer, "Candy Products" http://www.candy-domestic.co.uk/about_us/Default.aspx is more likely to provide an authoritative answer than anyone else. They seem to manufacture their own machines, answers based on experience with other makes and models are of no value to you in regard to this question.
the foregoing aside, what one man has made, another man can also make, or repair. It is extremely unlikely that Candy paid to have an exotic one of a kind bearing made for this washer. However, even if the bearings are a common industrial part, that doesn't mean that removing and replacing them is easy or cost efective, or even the cause of the noise.
Unless you have more expertise than your question implies, perhaps you should ask to have a Candy repairman diagnose the noise and if your diagnosis is confirmed give you seperate prices for the bearings and the installation of same. From that you can discern how long the professional repairman familar with the machine would require to do the work, and you should double or triple it to estimate how long it will take someone unfaniliar with the machine to do it
Feb 12, 2012 | Candy Washing Machines
Lost and need instuctions for cotton candy machine
The Instructions and Recipes for your Nostalgia Hard & Sugar Free Cotton Candy Maker PCM805 can be found here:
http://nostalgiaelectrics.com/manuals/pcm805.pdf
Thank you for using FixYa!
Aug 14, 2011 | Nostalgia Retro Cotton Candy Machine Maker...
CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Feb 22, 2010 | Candy F248P Electric Single Oven
Dryers Logo
80 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
