Question about Nintendo DSi Blue Console
How do you check the required polarity - Nintendo DSi Blue Console
My 2001 GPR1200 put my battery in,new plugs,new fuel filter.Went to start and nothing except noise coming from black plastic box ,that plug wires go into where fuses are. anything i can do?
Check the polarity of your battery install...
I'm not getting any US market reactions ...
You are posted GPR1200 under "car & truck"..
So generally... typically...
BBB Industries (registration required) carries MOST circuit drawings for popular USA marketed vehicles...
ELSE...
Buy the Factory+workshop+manual
(other than some "polar" capacitors... I don't believe all the DRAMA about a simple polarity reversal...
Just look for the sooty spots and fix'em
(in my humble opinion)
Jul 03, 2016 | Cars & Trucks
Where can I find an adaptor to fit a Hohner Keyboard PSK75 9 volt
You can actually use any 9 Volt adapter, as long as the adapter's Amp rating is higher than what the keyboard requires, and the polarity of the plug corresponds to that of the keyboard.
The keyboard consumes 7.7 Watt maximum, which means any 9V 1A (1000mA) adapter will do, but check the polarity on the plug.
Dec 31, 2015 | Computers & Internet
Plugged in 9 dc adapter but not getting any power?
It is possible that the adapter does not have the correct polarity required by the device you plugged it in. Check the polarity diagrams on your adapter and your device, They must match : Plus (+) on the outside, or + on the inside.
Sep 25, 2013 | WatchBuddy Dancing Skeleton in Top Hat...
The power on my banshee is coming on?
Check the polarity of the adapter, if it isn't the original one. Even if you have the right voltage, it still has to have the mA or higher but, most important is the polarity. Most guitar pedals are wired backward on the plug. The positive is on the outside ring of the plug and negative is in the middle. There should be a picture or diagram somewhere on the unit close to the plug to find out. If it is backwards, it could have damaged it, maybe not though. If it is ok, cut the plug off and switch the wires and check it. After all, it's not working now, it couldn't hurt.
Mar 15, 2013 | Rocktron Banshee Guitar Talk Box Talkbox...
Display fading weak
New battery required or wcs water inside unit.
Feb 20, 2012 | Polar GRAY POLAR HEART RATE MONITOR FS3...
REQUIRE MANUAL FOR F4 C716G00457925 MY BATTERY HAS BEEN CHANGED.BY POLAR . AND HAS WIPED ALL SETTINGS. NEED HOW TO USE GUIDE
For all those who lost their Polar Heart Rate Monitor manuals. Follow this link, fill in the details and get manual. Plenty of other Polar product info and support on this site.http://www.polar.fi/en/support/downloads?product=&category=User+manuals
Nov 22, 2010 | Polar F4 Heart Rate Monitor Watch
What the parameters (The voltage and polarity) of hjwer adapter for the monitor VIDEOSEVEN E17PS?
grigory27419, I wonder why they didn't print or emboss the polarity symbol on or near the place where the plug is inserted into the back of the monitor? I saw a specification that said it requires 19volts dc. But it didn't mention anything about how much current ( 1.5amp, 1.7 amp, 2.1 amp???) it requires. More importantly, why or what caused failure of original "black-brick" supply??? 12fixlouie
Sep 12, 2010 | Computers & Internet
What kind of battery is required for a Polar CS300 wrist computer?
It is a CR 2430.
It's a very tricky job to change the battery, watch out for the small springs that fly out when you dismantle it.
Polar recommends sending it back to them for a battery change where they also check the waterproof seal etc. I would recommend this as it's only about $16. Well worth it.
Mar 20, 2010 | Polar CS300 Cycling Computer
Nintendo DSi Blue Console Logo
24 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
