Question about Bosch Axxis WFL 2060 Front Load Washer
Cannot get to drain washer if the hose needs to go up into ceiling to get to septic pipes
I just bought this washer (used) and the previous owners had the washer on their main level, but I was planning on putting it in my basement. The drain hose needs to go up into my septic drain. When attached to the septic drain, the washer will not drain at all. If I have the hose just pour into a bucket on the floor, then the machine drains fine. However, I cannot keep emptying the washer into a bucket and dragging this bucket outside to pour it out! Is there a limitation with this washer that there is not enough pressure for the drain hose to go up into the ceiling to drain?
  • hjacob71 Oct 28, 2008
    Well I definitely am not going higher then 4 feet. I tested how high I could hold the hose up and once I got to be about 1 foot above the washer, it stopped draining.
    Do you know if adding the pump in line something any plumber could probably do, or will I need to find a bosch repair in my area?
    Thanks!
    ok thanks!! prob will hire a plumber for that though ;) much appreciate your input tho!
    Genius:
  • 1,605 Answers
Usually the outlet and the pump is capable of pumping out at the maximum high of 3-4 feet from the drain. if any higher than that, you need to add a pump in line.
Posted on Oct 28, 2008
  • Frank
    Frank Oct 28, 2008
    any plumber will do.
    if you are handy, go to any home center and get a pump and some hose, clamps.
    you are in business.
Septic vs washout tub?
Waste water from the washer is not pumped out but rather is gravity fed down the drain. You cannot drain the water up higher than the washing machine's drain outlet. You would have to cut into the drain pipe - below the level of your washer's drain outlet - and put in a T that will tie into the drain pipe and allow for some type of connection to be made from your washer's drain hose.
Mar 23, 2014 | Washing Machines
Bosch nexxt 3200 washer
The clog may have gotten into the line to the septic tank.
Dec 15, 2013 | Washing Machines
I have a Sears Kenmore washer, model # 110.28922791. I bought it approximately 10 years, give or take a year or two. I know it does not have a lint filter but is there any way to clean whatever processes...
HI- Washer really don't have a lint filter so to speak. Some of the front load washers have a filter in the drain pump but that basically just keep the quarters and bobby pins from ruining the pump. Is it possible to have someone extend your standpipe with a larger diameter pipe that you could place a screen into, or place the screen on the drain hose and then put them both into the larger pipe. A plumber should be able to figure something out. It would be about $1000 dollars cheaper than buying a front-loader and probably more effective. Good luck.
Sep 24, 2010 | Washing Machines
Washer will not drain or spin with pipe in specific washer drain but will if placed in the sink We have moved house and the new house has the usual pipework behind the washer. The machine will fill and...
Hi.
ok Did you say the drain hose was placed on a spiggot underneath the sink???
the appliance is obviously working as you have tried the drain hose in the sink.
You may find, if you unscrew the drain spiggot, there is a blanking cap. your previous owners put this in place to stop a huge water leak when using the sink
remove cap, refit hose and it should work ok.
Please let me know if I was right?
regards
aardvark Repairs
Nov 18, 2009 | Hoover Washing Machines
Washing machine is in the basement. we have a new septic system and the washer had to be hooked into the septic. (it previously had gone into a dry well. To do this we have the hose of the washer going up...
yep actualy a fairly common problem install a laundry tub with a pump and a diaphram switch (similar to a float switch but neater) will save your washing machine pump too Good Luck
Oct 12, 2009 | Washing Machines
We live in a mobile home, and whenever i do laundry thos terrible stench like seafood smell shows up in the hall. there is no leak under the trailer, is it something in the pipes that i can pour in the...
In mobile homes you have one drain pipe out. old water in the pipes can make a sludge and after a day or two can smell. My shower drain is open and i can smell the water when my washer drains too. White vinegar helps. Or if you have a septic tank your drain field may be clogged up and backing up into your pipes where they slowly drain.might be time for pumping your septic tank.
Sep 19, 2009 | Washing Machines
My Washing Machine fills and drains at the same time, what can i do? I have just about the same problem. We had put in a new drain line for my washer. This new line has been on for over a month W/O any...
Yes, it is a siphon problem.
Check the hose where it goes through the wall. It may be pinched and cutting off air.
If air cannot enter the hose it will siphon. If the hose is too low it will siphon.
May 23, 2009 | GE Washing Machines
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
roof.
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
home.
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Error 4 in bosch nexxt washer
After browing a little more on this forum, I found the solution to my problem.
There was an hairpin stock in the rotating device that is located behind the front plastic cover.
Thank this website was very useful to me. Hope it can help someone else too!
Jan 13, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Axxis WFL 2060 Front Load Washer Logo
145 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
