Question about Frigidaire ATF6000ES Front Load Washer
GLTF2940FS1 DOES NOT FILL, SPIN OR DRIAN
THE MACHINE WILL PUMP IN A LITTLE WATER STOP FOR A FEW MINUTES PUMP IN A LITTLE MORE WATER THEN STOP. IT DOES NOT GO INTO THE SPIN CYCLE OR DRAIN CYCLE...
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
docjohn174
  • 943 Answers
SOURCE: I just had a Frigidaire
hi thanks for the question make sure both water taps to washer are on check that because if the cold water if off it wont go into rinse cycle thanks the appliance doc
Posted on Sep 27, 2008
  • 71 Answers
SOURCE: Washer will not spin
My mum had this problem. I think it had something to do with the barrel coming loose.. - get a plummer ;)
Posted on Sep 29, 2008
SOURCE: Hi, my washer will fill, agitate, stop and not drain or spin.
Hi everyone, I found the solution to my washer problem. I checked the lid switch and it was ok, but the lid lock was damaged. I opened the lock and I solder it and the problem was solved.
I hope this info can help someone.
Posted on May 28, 2009
localwonder
  • 6784 Answers
SOURCE: Won't spin after wash cycle or rinse cycle
CHECK THE FOLLOWING---
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on May 31, 2009
Frigidaire Frontload Washing machine Model GLTF2940FS1 will not spin out the water all the way and the clothes remain soaked with water. The drum does a few rotations in both directions but then shuts off...
Good Morning Lydia,
Based on what you have described and since you have already replaced the pump and checked for any possible kinks, at this time I would recommend reaching out to a professional to proceed further. The washer may possibly be experiencing an issue with the door lock assembly, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, a diagnoses is highly recommended.
Thank you for allowing me to assist you in some small way!
Sep 08, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer does not always enter a high speed spin
look for blockage at inlet of water drain pump i found a sock in that area and it fixed my problem same problem you have
Apr 13, 2009 | Washing Machines
Will not spin during any cycle w/ or w/out clothing inside
that sounds like something else, I had a similar problem yesterday, the washer would stop after a few mins, I traced the fault to the water hoses, it was plummed in with a hot water feed that can get dirty over time. this had blocked the inline fiter stopping water getting into the machine, if it does not fill within three minutes it can cancel, I cleaned the filter and was out in 10 minutes.
I just had a Frigidaire front load washer installed today model #GLTF2940FS1 and I am having a problem with the rinse cycle. When the wash cycle is completed and the spin cycle the machine will stop at 26...
Sep 27, 2008 | Frigidaire Washing Machines
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Frigidaire ATF6000ES Front Load Washer Logo
70 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
