Question about Admiral AED4475TQ
Dryer suddenly stopped heating
One load fine and next load hours later did not heat. What could be problem?
  • 4 Answers
Heating element, thermostat or thermal fuse
Posted on Feb 24, 2012
Bosch WTVC3300 dryer keeps tripping reset button
If it keeps reseting, check if the ventilation house is clean, also check if the dryer blower is clean in convention with the filter conductor.
Jan 14, 2014 | Bosch Dryers
I HAVE A GE DRYER THAT WAS WORKING FINE ONE LOAD THEN STOPPED HEATING UP ON THE NEXT LOAS.IT TURNS FINE BUT NO HEAT
either your heating element,cycling heat switch,hi-limit switch,or thermistor are defective also check power input for 240 volts,if one leg 120 volts is missing it won't correctly
Oct 31, 2009 | GE DVL223EBWW Electric Dryer
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Low heat output
A clogged or partially clogged vent . Especially if vents up thru the wall . If it vents straight out , make sure you have good air flow to the outside . Make sure the vent hose has no sharp kinks also . Try drying a load with the vent hose disconnected from the dryer . If clothes dry fine , that tells you the problem is elsewhere . Normally , a dryer either heats or doesn't heat . A heat for a few minutes then stops heating but continues to run complaint ,would be bad coils on the gas valve .
Jul 19, 2009 | Dryers
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
Dryer is not heating air
Sounds like the heating element or coil is out, but it could also be the board to. At any rate, if your not getting any heat what so ever, its more than likely electrical and its best to take it in. If it gets some kind of heat, then you might try cleaning out your dryer vents really good, and also in the dryer. Hope this helps.
Jan 02, 2009 | Maytag SDE3606A Electric Dryer
Whirlpool awg 338 washer
initially check the element for continuity then check that any part of the wiring has not come off. if the water does not heat up it may not be advancing the timer to continue with the later stages of the wash, ie waiting for the stats to say the water is warm enough. tone.
Jun 04, 2007 | Whirlpool AWG329 Front Load Washer/Dryer
Admiral AED4475TQ Logo
291 people viewed this question
Top Admiral Dryers Experts
Lawrence Oravetz
Timllfixit
Are you an Admiral Dryer Expert? Answer questions, earn points and help others
